It is currently Thu Aug 21, 2025 5:29 am
PostPosted: Tue Sep 10, 2013 5:55 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
The first picture shows what I'm talking about. I used StewMac's "red" purfling around the top and the rosette. The FB markers and peghead logo are red recon stone...a dark red. The purfling really looks more pink than red when looking at the features altogether. They don't match at all [headinwall]
The second picture shows an offcut of the top wood with strips of the purfling glued to it, and then each has a different color shellac over it. One of the position markers is below the darkest for comparison. I don't feel that even the darkest shellac changes the purfling enough, and I don't want the top to be much darker than that darkest color.
Anyone have any ideas how I can reduce the contrast between these colors (or should I use the dark shellac in the picture and forget about it). This guitar is not being built for anyone in particular and if it ends up with someone other than me, it will almost certainly be a gift. So it's not the end of the world. But it's annoying.
Thanks, Beth
PostPosted: Tue Sep 10, 2013 6:01 pm
First name: nick
Last Name: dingle
Use the darkest and forget about it. Looks like a great guitar. It is very hard to match disparate materials, especially, at this stage......
These users thanked the author nickinbruns for the post: Beth Mayer (Tue Sep 10, 2013 11:50 pm)
PostPosted: Tue Sep 10, 2013 7:22 pm
Last Name: Imbler
State: KS
Zip/Postal Code: 67204
I've always thought that if you can't match, a large contrast is a good thing,
These users thanked the author Imbler for the post: Beth Mayer (Tue Sep 10, 2013 11:50 pm)
PostPosted: Tue Sep 10, 2013 9:46 pm
Beth, six months from now you won't notice the difference, a year out you'll forget about it.
I think it looks ok. In fact, to tie it all together, you could inlay some of those recon dots in the rosette.
Pick some regular pattern, or go completely random. It will make it all look intentional.
If someone ever asks bout the color difference, you could put a patient smile on your face and speak to them in sympathetic tones about how they don't see the beauty.
These users thanked the author Steve Kinnaird for the post: Beth Mayer (Tue Sep 10, 2013 11:50 pm)
PostPosted: Tue Sep 10, 2013 10:51 pm
First name: George
City: Seattle
I'm kind of persnickety about such things and I think it looks fine. The two reds may not match, but they compliment one another nicely. If it really, really bugs you, Steve's idea of introducing a bit of the recon stone elsewhere would tie everything in quite well.
George :-)
These users thanked the author George L for the post: Beth Mayer (Tue Sep 10, 2013 11:50 pm)
PostPosted: Tue Sep 10, 2013 11:53 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Thanks, All! I'm documenting this build in a Doc-U-Build thread, so you'll probably see it finished. I am going to use the darkest shellac, and leave it at that. I like the idea of using the stone dots in the rosette, but I'm a little nervous about inlaying the rosette at this point, and I would have to order more dots.
Hopefully it won't be that noticeable. I appreciate the input.
PostPosted: Wed Sep 11, 2013 12:02 am
I think once you finish the guitar it will look way better to you.
Drive on, Beth.
PostPosted: Wed Sep 11, 2013 8:45 am
First name: David
Last Name: LaPlante
Remember that finishing in a darker shellac is quite tricky in that an uneven layer can easily become blotchy looking.
You could try a very dilute solution of potassium dichromate which will darken everything (after it is applied wet and exposed to bright sunlight).
The particular toning of this compound should bring the colors closer together.
Test, Test, Test different solutions on the same materials before you apply!!!
Also wear gloves with this stuff and keep it well away from pets and children.
http://www.bt3central.com/showthread.php?t=27343
The other problem with shellac is that it's quite orange (lots of yellow) which just intensifies the red/orange of the purflings, the dichromate has a very slight greenish cast (red plus green =brown) which I think will tone it closer to the dots. You will confirm this hopefully by experimentation.
PostPosted: Wed Sep 11, 2013 10:23 am
were it mine i might consider dyeing the edges of the red purf darker with the finest of brushes. or maybe even plucking out the stone markers and breaking up their contrast using the same purfling scheme. fwiw, i use lmi's red purfling and i find it to be darker then sm's.
PostPosted: Wed Sep 11, 2013 11:05 am
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
That looks really interesting and I might try it. I don't know how much tannin is in spruce. It might really make the quilted Mahogany prettier if I used it on back and sides as well. Thanks for the tip!
PostPosted: Wed Sep 11, 2013 11:11 am
Last Name: Smith
City: Graton
Zip/Postal Code: 95444
I agree with others that once you finish those purflings are going to darken and deepen significantly. Can you wipe it with naptha and get a better idea of how it will look finished? That said if I really hated it I would drill out the dots and replace with slightly larger.
Michael F Smith
Goat Rock Ukulele
http://goatrockukulele.com
PostPosted: Wed Sep 11, 2013 11:23 am
First name: David
Last Name: LaPlante
I've used the dichromate to darken spruce (considerably) a number of times.......the dilution will vary the effect.
