It is currently Thu Aug 21, 2025 6:12 am
PostPosted: Sun Jun 23, 2013 12:15 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I got on my bench one of those "cheap" (compared to custom/high end guitars, around 1000 dollars) Martin 000. The back has somehow separated from the side in the upper bout in that area. The guitar is brand new, however the customer bought it online from a store in the US, had it shipped to Taiwan. The store wants to help but he would have to mail the guitar back, probably costing 200 dollars or so to do it. I charged him half that to get it fixed.
The question is, how could this possibly happen? The back is separated from the side and the side has moved inward a little bit. I don't know if it was glue failure or someone pushed it out. What kind of glue does Martin use?
Typhoon Guitars
PostPosted: Sun Jun 23, 2013 1:33 am
City: chicagoland
State: illinois
sounds like expansion from being introduced to a humid environment...i wouldn't blame the glue, rather than the joint prep- poor fitting, sounds like.
PostPosted: Sun Jun 23, 2013 2:11 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
You sure? It sure doesn't look like it... it feels almost like it was forced out from the inside or someone hit it in the wrong way. I'm not seeing any sign of exposure to extreme humidity...
How much humidity does it take for a guitar to become damaged? I heard too low of a humidity is much worse than too high.
Typhoon Guitars
PostPosted: Sun Jun 23, 2013 7:25 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
If the joint was compromised in some way via contamination or another factor during construction a slight impact could have caused this on an unbound guitar. The bindings are not just decoration, they serve the purpose of protecting and reinforcing the joints of the plates to the rims. Once the joint pops the rim will move in whatever direction the stress dictates, this is one of the drawbacks to forcing rims to conform to molds during construction, it induces stress into the joint to start with. If the joint is weak and already under duress it will not take a lot to make it fail completely. The changes in RH during shipping may have been enough extra stress to cause failure as well. If it was new it should have been covered by Martin's Factory warranty, though I don't know what that would mean where you are.
Brian
PostPosted: Sun Jun 23, 2013 7:43 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
I think Martin uses plain old Titebond.
Kevin Looker
I'm not a luthier.
PostPosted: Mon Jun 24, 2013 12:39 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Probably a bad glue joint or it got bumped in shipping. Maybe some of both.
Can you push the side out from the inside? I'd guess the bend relaxed once it was free of the mold and glue joint. Re-gluing should work fine. Put a knife blade in the crack and pry GENTLY to see if more of the joint is bad.
PostPosted: Mon Jun 24, 2013 12:45 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I pushed it out as much as I could but I couldn't push it anymore past a certain point... so now there's a tiny (maybe .003"?) lip that I'll have to sand off and touch up to hide it.
Typhoon Guitars
PostPosted: Wed Aug 21, 2013 2:18 pm
Last Name: Cox
I saw that on some of the bottom of the barrel Martins and Taylors...
Upon closer inspection - it looked like they were painting the components - THEN gluing them together... and got some overspray on the glue areas.... and tried to glue them anyway.... At least, that's the only way I could figure out how they got paint INSIDE the glue joints like that....
If you look at them wrong - *Ker-poink*
PostPosted: Wed Aug 21, 2013 2:39 pm
First name: Rusty
about 1/4" below the top, beneath the separation, center of picture, is that an ouchie I'm seeing?
