It is currently Fri Jul 25, 2025 4:07 am
PostPosted: Thu Aug 08, 2013 6:16 pm
First name: Phillip
Last Name: Patton
City: Yoder
Zip/Postal Code: 46798
Finally got this one done, after letting it sit on the shelf for months half finished. At least, it might be done; I may add a logo inlay to the headstock, which would mean refinishing that area...
Anyway, the body and neck are mahogany, the top is claro walnut (gorgeous stuff!) and the other wood parts are all african blackwood.
It has a single humbucker, wired for series/parallel. Sounds pretty good! I'll try to record a sample, but my recording setup leaves something to be desired...
Of course this is pretty unconventional, and I may never sell it for that reason (though I'd like to), but I have a thing about weird instruments, and I just had to make it. Now I'm thinking about making a soprano size (this one is a tenor).
I need to clean up the fretboard a little too...
Regards,
Phillip Patton
http://www.pattonblades.com
The bitterness of poor quality lingers long after the sweetness of low price has faded.
https://hoosierbladesmith.wordpress.com
These users thanked the author Phillip Patton for the post: GRD (Wed Aug 21, 2013 7:50 pm)
PostPosted: Thu Aug 08, 2013 6:18 pm
First name: Phillip
Last Name: Patton
City: Yoder
Regards,
Phillip Patton
PostPosted: Thu Aug 08, 2013 6:46 pm
Darn near perfect, ain't it?
PostPosted: Thu Aug 08, 2013 8:20 pm
Absolutely gorgeous!
(I was desperately trying to remember the quote in your sig earlier!)
PostPosted: Thu Aug 08, 2013 8:31 pm
First name: Patrick
Last Name: Hanna
State: Missouri
What's not to like? Dang! Fabulous.
Patrick
PostPosted: Thu Aug 08, 2013 9:04 pm
First name: anthony
Last Name: wickman
City: tallahassee
State: florida
Zip/Postal Code: 32301
Very cool piece, bravo!.
PostPosted: Fri Aug 09, 2013 12:48 pm
First name: D
Last Name: S
Beautiful!
The finish is impecable!
wah
Wah-wah-wah-wah
Wah
PostPosted: Sat Aug 10, 2013 12:04 am
+10! Very sweet.
Did you build the pickup, or buy it aftermarket. If the latter, what is it?
PostPosted: Sun Aug 11, 2013 6:32 am
First name: James
Last Name: Tonguet
City: Duluth
State: Ga
Zip/Postal Code: 30096
Outstanding , stunning work !
PostPosted: Tue Aug 13, 2013 11:11 am
First name: Phillip
Last Name: Patton
City: Yoder
Thanks, fellas, for all your comments!
Mike Baker wrote:
+10! Very sweet.
I built it myself. I did find some people selling uke pickups, but the prices were so high, I just decided to do it myself. I like to have control over all the creative processes anyway, though.
Regards,
Phillip Patton
PostPosted: Wed Aug 14, 2013 11:31 am
First name: Dalton
Last Name: Barham
City: taunton
State: somerset
Zip/Postal Code: ta3 5hp
Country: england
hi! i have a few questions as i'm just about to undertake a similar project myself!
firstly, how did you know when to stop winding the pick up, did you measure the number of turns, or the resistance?
and secondly, where did you get your strings!
PostPosted: Wed Aug 14, 2013 5:14 pm
First name: Phillip
Last Name: Patton
City: Yoder
Howdy,
I made a pickup winder out of a fishing reel. The reel crank hits a small switch with each turn, which is connected to a calculator which then counts the turns. Then you have to multiply that number by the gear ratio of the reel to get the actual number of turns of wire. When I get close, I scrape some of the varnish off of the wire, and check the resistance with a meter, and if it needs more, paint some lacquer where I scraped, and keep winding. You can find plans for the winder online.
The strings are just regular electric guitar strings, like these:
http://www.sweetwater.com/store/detail/EXL110-3Pk/
For tenor tuning, use the DGBE strings. For baritone, use the ADGB strings. You might have to experiment with different guages.
Have fun! If you have any more questions, ask away.
Regards,
Phillip Patton
PostPosted: Thu Aug 15, 2013 8:27 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Awesome, design, execution, everything!
What's your final finishing routine - grits to level then what do you do final polishing with?
Kevin Looker
I'm not a luthier.
PostPosted: Thu Aug 15, 2013 12:25 pm
First name: Phillip
Last Name: Patton
City: Yoder
Kevin Looker
Thanks, man!
I pore filled with Zpoxy, then sprayed with shellac sanding sealer, then sprayed with about 12 coats of fairly thin Behlen lacquer. Let it cure for a couple weeks, then level sanded with 1000 grit paper using my ROS, then buffed with Menzerna ultra fine compound with an electric buffer.
Regards,
Phillip Patton
PostPosted: Fri Aug 16, 2013 8:55 am
First name: Tim
Last Name: Skau
City: NARVIK
Zip/Postal Code: 8514
Country: Norway
This looks really amazing. Good job, and really inspiring :-)
It's funny, I saw this video today, and it's obviously more you can do with a ukulele than I thought :-)
http://www.youtube.com/watch?feature=pl ... ylxBtEM0sI
best regards,
Tim
PostPosted: Sat Aug 17, 2013 5:51 am
First name: Ake
Last Name: Bjornstad
City: Gotheburg
Zip/Postal Code: 41143
Country: Sweden
Nice work.
