It is currently Thu Aug 21, 2025 10:08 am
 Post subject: Re: Bridge vacuum clamp?
PostPosted: Fri Jul 05, 2013 8:01 pm
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
The LMI vac clamp is great. In between uses though, you have to protect the surface that comes into contact with the top. DAMHIKT :-)
PostPosted: Fri Jul 05, 2013 9:18 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
I have the LMI clamp because I was too lazy to make my own. It's great. You can get the rubber from LMI as well. I have made a couple of vacuum clamps of different sizes with the rubber I bought from them. You could get the rubber from them and make your own bridge clamp.
PostPosted: Fri Jul 05, 2013 10:32 pm
First name: Ringo
JSDenvir wrote:
The LMI vac clamp is great...
PostPosted: Fri Jul 05, 2013 11:17 pm
I guess I'm assuming it's a silicone rubber membrane and an aluminum frame.
These guys should have you need if your interested in going that route.
http://www.torrtech.com/
I use a vacuum bridge clamp I made, works fine. I'll try to get a picture for you if you want.
Here's a photo of bag I made in situ to reattach a bridge on a 10 string, my clamp wasn't long enough.
As you can see, way too much glue, but good pressure, the guitars doing fine 2 years down the road.
the bags kinda ugly though, but the guitar cleaned up nicely.
PostPosted: Sat Jul 06, 2013 12:12 am
First name: Blake
Last Name: Dixon
City: Kelowna
Zip/Postal Code: V1V1W7
What do you use to protect your clamp? I have one as well and just keep it in a zip lock bag?
Blake
Blake Dixon
Kelowna B.C.
PostPosted: Sat Jul 06, 2013 1:49 am
First name: David
Last Name: Eddy
City: Mandeville
State: La
Zip/Postal Code: 70448
Just made mine last week! I'm getting my gasket tape & vinyl from Joe woodworker http://www.veneersupplies.com/
I bought a cheap chopping board from Walmart and tapped #10 panhead screws every 1".
PostPosted: Sat Jul 06, 2013 6:26 am
I've replaced the rubber membrane and the foam weatherstripping material on my LMI clamp. They sell the parts and it's easy to do. Make sure you store it face down on a flat surface or if face up, don't put anything on it. It doesn't take long to deform the foam, even with light pressure. Typically, I take it off after 10-15 minutes and clean off all the squeeze out both from the bridge and from the clamps, then reclamp. Keep it clean or you're asking for trouble. And I'm sure we all know it's only going to fail after the glue is on and time is pressing.
Mike Lindstrom
PostPosted: Sat Jul 06, 2013 8:34 am
Last Name: Killin
I built mine with the rubber from an exercise stretch band. They come in different thicknesses and you can get them in pretty much any department store sporting good section. I used a thinner material because it is what I had. Next time I’ll go thicker.
The frame was made from 1/4” sheets of acrylic that I laminated together with acetone. I stuck the rubber down with RTV gasket sealant then screwed the top half of the frame down. The gasket is the LMI gasket.
Steve Smith has a plan for one in the tutorial section.
http://www.luthiersforum.com/forum/viewtopic.php?f=10117&t=23895
PostPosted: Sat Jul 06, 2013 9:51 am
Last Name: Renick
City: Mount Shasta
State: ca
Zip/Postal Code: 96067
Country: us
I have making one of these on my list as well. I found this thread with some helpful info:
http://www.luthierforum.com/index.php?/ ... uum-press/
Ebay sources for rubber:
http://stores.ebay.com/Jet-Gasket-and-S ... 7675.l2563
http://stores.ebay.com/RuBBeR-HoUsE-wAs ... 7675.l2563
No rubber but a good source of vacuum stuff, they have some breather release film that looks useful: http://www.avtcomposites.com/cgi-bin/co ... egory=1300
I have done the bond plexi with acetone trick for other vacuum fixtures, works well, so I am planning that route. I wonder if some scrap from an old wet suite would work for the neoprene?
http://shastaguitar.com/
http://www.kalimbakit.com/
PostPosted: Sat Jul 06, 2013 11:28 am
I see I somehow lost a few sentences in my post above.
I was trying to imply that it's possible to patch silicone rubber using GE RTV 108 adhesive and that Torr Tech has supplies for patching or building vacuum clamps.
The bridge clamp I made looks a lot like the one John Killin posted BTW.
PostPosted: Tue Jul 09, 2013 11:38 am
Last Name: Garrish
Filippo Morelli wrote:
Hi Guys,
Well my St. Lutherie bridge vacuum clamp gave up the ghost. The rubber tore right where it is glued to the frame. Best as I can tell the glue bled out when the rubber was affixed to the frame, leaving a jagged edge where the rubber eventually tore. I did get about 6 guitars or so glued up with it before it gave up the ghost and I'd like to continue vacuum clamping bridges.
Does anyone have a recommendation as to where to buy a vacuum clamp?
Thanks!
Filippo
Aww poop! The last time I made that style was six years ago, I made a few with top plates after that but they cost double. I'd put it over a jointer to clean off the top of the acrylic and glue on another piece of rubber if you want to fix it up on the cheap- you can get a 12"x12" piece of neoprene sheet for $6 from McMaster Carr, or ~$10 if you want adhesive backed. I'd send you some for free, but the shipping would cost more than the shipping plus the product from McMaster!
The rubber is neoprene rubber, which is different than neoprene foam (which is what a wetsuit is). If you want other choices, you can look up 'rubber sheet' on Amazon Supply; they have all kinds of weird stuff, and their pricing isn't half bad.
Bob Garrish
PostPosted: Tue Jul 09, 2013 1:19 pm
First name: Blake
Last Name: Dixon
City: Kelowna
Pool liner might work as well as long as you get the thin stuff. It seams to stretch a lot!
Blake.
Blake Dixon
Kelowna B.C.
PostPosted: Thu Jul 11, 2013 7:35 pm
Last Name: Garrish
Bob Garrish wrote:
Aww poop! .... I'd send you some for free, but the shipping would cost more than the shipping plus the product from McMaster!
laughing6-hehe yeah no kidding. Shipping has gotten cuckoo.
I thought about making my own, just because $100+ship from LMI seems a bit on the expensive side. I had not thought about fixing this one ... but then again doesn't seem like this is too hard to make.
The rubber on yours had some transference to the finish on the last guitar I did. Now I had the vac clamp on way longer than it needed to be ... and likely it would not have happened with 20-30 minutes and hide glue. Is neoprene rubber the way to go, or is there some other wisdom on this?
Filippo
I'm not sure exactly what you mean by transference, like a texture or did it actually adhere? On a fully cured finish, nothing should be able to affect it, but the only finishes which are truly 'fully cured' in a reasonable time in lutherie are polyester and polyurethane. Your best bet to prevent any sort of reaction is silicone rubber, it's the most inert (and expensive) of the common rubbers, though that'll only help if it's a borderline problem.
The other option is to use something like vinyl sheet (shower curtain) for the membrane. It'll work just as well...I've done more than a couple vacuum clamping runs with garbage bags sealed to a hose with rubber bands- so long as it keeps the air out it'll work.
Bob Garrish
PostPosted: Thu Sep 05, 2013 11:32 am
Last Name: Potter
City: Port Saint Lucie
State: Fl.
Zip/Postal Code: 34984
Hi Guys I do not post much as I had to sell all my tools and wood to pay bills and such. I used plastic window material, the stuff they use for windows in canvas covers for boats, it can be found at any fabric store its super cheap and works great.
Users browsing this forum: doncaparker, Ken Lewis and 19 guests
