It is currently Thu Aug 21, 2025 5:32 am
PostPosted: Sun May 05, 2013 2:03 pm
First name: Tim
Last Name: Skau
City: NARVIK
Zip/Postal Code: 8514
Country: Norway
Hi.
I am new to the forum and new to guitar repair/maintenance/lutherie.
A little bit about me : I live in the northen part of Norway, I have been playing bass and guitar for around 25 years, and been getting into this whole arena of guitar repair/maintenance and building.
I have made saddles, nuts, done refrets and fret levellings, soldering and pickup replacements and built a bass from a kit.
Now I am getting more into acoustic guitar repair and bridge work.
I got a cheap acoustic guitar that I am fixing up for my daughter, and I need to replace the bridge on it and of course gluing it on. And this is my question :
what clamps should I get?
I have seen the bridge clamps, cam clamps and soundhole clamps on stewmac, and also the bridge clamps and the FOX bridge clamps on the LMI website.
I am currently leaning towards a set of 5" and 7" soundhole clamps from StewMac with the soundhold clamp cauls.
What is your recommendation and experience on this?
Thank you in advance for any replies
Best regards,
Tim
PostPosted: Mon May 06, 2013 8:44 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Are there cheaper ways to buy those soundhole clamp? I find them very useful for bridge glueup but at 20 dollars a clamp for what looks like cheap Chinese junk, it's way too expensive.
Typhoon Guitars
PostPosted: Tue May 07, 2013 1:59 am
Last Name: Shaw
City: Phila
State: PA
Zip/Postal Code: 19125
The shop fox version of these clamps go for $12.40 on amazon. They are pretty decent clamps.
PostPosted: Tue May 07, 2013 2:43 am
I prefer to use 3 deep throat clamps, and skip the SM bridge clamping caul altoghther. This allows me to use a flexible, kerfed wooden internal caul, which will conform to any soundboard geometry, which suits my building style better. The SM bridge caul depends on a rigid internal caul, or it may distort the bridge and soundboard when clamping pressure is applied. I usually use 3 Ibex clamps, but other deep throat clamps such as Klemensia cam clamps, or regular steel C-clamps will work equally well. One thing to keep in mind if you use very heavy clamps, is to support their weight near the soundhole, for example with a stick that spans the soundboard, or their combined weight may twist bridge/ soundboard towards the soundhole.
Og forresten, velkommen til OLF til ennĂ¥ en nordmann! [:Y:]
PostPosted: Tue May 07, 2013 3:22 am
First name: joseph
Last Name: sallis
City: newcastle-upon-tyne
State: tyne and wear
Zip/Postal Code: ne46xe
Country: UK
Arnt Rian wrote:
This allows me to use a flexible, kerfed wooden internal caul, which will conform to any soundboard geometry, which suits my building style better. [:Y:]
Arnt, this sounds interesting. Any chance of a photo?
We are all in the gutter but some of us are looking at guitars.
PostPosted: Tue May 07, 2013 6:13 am
I don't have a one handy, but picture a "normal" internal bridge caul, with cut-outs for the X-braces, and shims that are equally thick as the bridge plate, for the area outside the braces. Then, a series of kerfs across (think kerfed lining), with a 3 mm or so "web" left on the back. The kerfs make it flexible enough to conform to any dome the soundoard has (or doesn't have). It is still rigid enough to act as a clamping caul for the bridge, as long as I use "normal" clamps, that is, not the SM bridge clamping caul.
PostPosted: Tue May 07, 2013 7:46 am
First name: Tony
Last Name: C
City: Brooklyn
I use a clamp similar to a Fox Bridge Clamp. Mine is made from birch plywood, but works the same way. I like it because there are no clamps in the way of the glue clean up.
http://www.lmii.com/products/tools-services/clamps-vises/fox-bridge-clamps
http://www.CostaGuitars.com
PMoMC
PostPosted: Tue May 07, 2013 8:00 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Did you make or buy yours, Tony? They look pretty easy to make from scrap aluminium.
Alex
PostPosted: Tue May 07, 2013 12:20 pm
Last Name: Beaver
City: Lake Forest
Arnt, s
Sure glad I read this threat. The kerfed caul sounds like the way to go. I usally make a caul from a piece of wood and some 'friendly plastic' it works OK but you have to redo it for individual guitars. Some times it is not as friendly as I'd like
Joe Beaver
Maker of Sawdust
PostPosted: Tue May 07, 2013 1:15 pm
I've actually made a number of kerfed cauls for various things but never a bridge caul. Brilliant Arnt!!
PostPosted: Tue May 07, 2013 2:47 pm
First name: Tim
Last Name: Skau
City: NARVIK
Country: Norway
Thank you all for your replies and input on this, I appreciate it :-)
@Arnt Rian - takk skal du ha, hyggelig :-)
best regards
Tim
PostPosted: Tue May 07, 2013 3:20 pm
First name: Ringo
Another vote for the Shop Fox/Ibex clamps... that is, when I can't use vacuum
PostPosted: Tue May 07, 2013 4:52 pm
First name: Mark
City: Concord
If you're in a mood to do it yourself (or can't afford commercial clamps), Matius Wandel has instructions for deep throat clamps that will exert >250 pounds with a 12" reach. You need scrap birch plywood, a section of threaded rod and a couple of nuts.
http://woodgears.ca/clamps/index.html
PostPosted: Tue May 21, 2013 11:28 am
First name: Tim
Last Name: Skau
City: NARVIK
Country: Norway
Thank you for feedback and pictures
Best regards,
Tim
PostPosted: Tue May 21, 2013 11:37 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
how do you keep the caul in position while you go grab that big cam clamp?
Typhoon Guitars
PostPosted: Tue May 21, 2013 5:30 pm
Really nice rosette, Todd.
PostPosted: Wed May 22, 2013 7:57 am
First name: Larry
Last Name: Hawes
Me too. Made simple one from plywood as well - works great.
Thank You and Best To All
PostPosted: Fri Sep 13, 2013 8:12 am
First name: Tim
Last Name: Skau
City: NARVIK
Country: Norway
Well, I did invest in the fox bridge clamps (classical, and steel), and some Bridge C-clamps, and I am now waiting for the shipment. Looking forward to testing them out.
I have a classical guitar that I will test it out on :-)
I did previously get some standard cam-clamps, and they are usable for just about everything it seems - i need to get more of them :-)
Tim
