It is currently Mon Jul 28, 2025 8:24 am
 Post subject: French polish
PostPosted: Wed Sep 05, 2012 2:36 pm
First name: Anders
Last Name: Clarmo
City: Malmö
State: Skåne
Zip/Postal Code: 21771
Country: Malmö
What are the pros and cons of French polishing when it comes to steel string Guitars.I have built a few guitars that I have polished with shellac intstead of nitrocellulose laquer mostly because of lacking spraying booth,gun and so on.
It is getting better,but not perfect as my brothers nitrocellulose finishes..
My main problem is that the finish get a little bit hazy,not 3-Dimensional
Sorry for my poor English...
Very thankful for any suggestion on how to improve my french polishing.
Anders C.
Sweden
 Post subject: Re: French polish
PostPosted: Wed Sep 05, 2012 5:38 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I'm in the minority but I like a FP finish on a steel string. Has a slightly brighter sound. My FP looks clear and glossy but due to it's thinness there is no mistaking it for anything other than a hand applied finish. Lacquer is what most people will want. As for the haze... not sure, a pic would help. What type of shellac do you use?
Brian
PostPosted: Wed Sep 05, 2012 7:48 pm
First name: Trevor
Last Name: Gore
City: Sydney
I use hard shellac on many of my SS tops and most of my CL tops. Most people think it's nitro, which is what the B&S usually are. Shellac works fine. It's not pick-proof, but neither is nitro.
http://www.goreguitars.com.au
PostPosted: Thu Sep 06, 2012 2:53 am
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
I do French polish finishes for several builders--classical and steel string. I won't pretend to not be biased, but I agree with Brian: French polish sounds better. I have test panels that I finished years ago. Anyone can hear that they ring better than bare wood panels. I don't have comparable panels sprayed with lacquer. Maybe they would ring the same.
I agree with Trevor, too. A thin finish (shellac, nitro, whatever) won't protect the soft wood of a guitar top.
PostPosted: Thu Sep 06, 2012 8:30 am
I have french polished only 3 guitars now but I don't think I will ever go back to water-base or Lacquer again because I like the FP so much. IF a cuatomer wants it of course then I will but I will do a lot of convincing first. I don't think it makes any difference that a guitar is a steel string or not for an FP finish. As was mentioned nothing is really pick proof and really I put just as many scratches in my classical guitars as I do with my steel strings. I just FP'd a Selmer guitar and I won't chalk the sound of that guitar up to FP but darn if it doesn't sound great!
I found FP to be a very easy finish to apply with great results. I'm not sure what would be causing hazing. Is your shop humidity controlled? Could be that you are getting water vapor under the finish. I finish at 45% RH and have no issues at all.
PostPosted: Fri Sep 07, 2012 2:11 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I will FP on new builds, however for restoration and repairs I generally use lacquer because most vintage instruments (unless it's pre 1900) have lacquer. Plus it takes a lot of time for me to FP a guitar.
Typhoon Guitars
