It is currently Sun Jul 27, 2025 2:58 am
PostPosted: Mon Sep 03, 2012 1:48 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
I have been working on my OLF challenge build and one other as well...
MK5acoustics.com
PostPosted: Mon Sep 03, 2012 4:39 pm
First name: D
Last Name: S
Wow,
The rosette pattern is awesome. How the heck do you do something that delicate?
It's only 102 today in Texas - fall must be coming. I hope to get back into the shop by October.
wah
Wah-wah-wah-wah
Wah
PostPosted: Mon Sep 03, 2012 5:26 pm
First name: Jim
Last Name: Kirby
That second guitar top is mighty unhappy looking!
I'm doing fretwork on guitar #7, a Lutz and Palo Escrito Romanillos-style classical, I do like how Palo Escrito looks and works.
Jim Kirby
kirby@udel.edu
PostPosted: Mon Sep 03, 2012 7:02 pm
I'm installing a b bender in some guy's telecaster
Old growth, shmold growth!
PostPosted: Mon Sep 03, 2012 7:36 pm
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
Basement renos. Should be the conclusion of a 5 year project. Total gut and rebuild.
http://redrivercanoe.ca/
PostPosted: Mon Sep 03, 2012 8:05 pm
Working on my challenge special. I designed a new shape and here it is roughed out. pretty much the same footprint as a normal steel string bridge but with more rounding. Black stripe is CF laminate ala Trevor Gore. Opinions are welcome.
PostPosted: Mon Sep 03, 2012 8:20 pm
Built the last four cabinets for work, repaired 4 guitars and wet sanded the neck for my dreadnaught (for the 2nd time). I saw a pile of parts that looked like my challenge build some time last week, I'll have to go through the thread to see what I was building.
PostPosted: Mon Sep 03, 2012 9:42 pm
Last Name: Burner
City: Lincoln
State: Nebraska
Zip/Postal Code: 68506
Built a jig to hold a guitar between wood and foam on my bench. Why I waited 3 years to do this is beyond me.
Did some scraping and sanding on 3 guitars.
Cut heel lengths on 3 guitars.
Added a heel cap to one of the 3 guitars.
Aligned a bridge on a new model (on of the 3) and drilled the bridge alignment holes.
Why does such a short list take so many hours???
P A U L B U R N E R
Burner Guitars
PostPosted: Mon Sep 03, 2012 10:46 pm
First name: Phil
Last Name: Hartline
City: Warrior
State: Alabama
I glued on the last back brace on No. 2, and finished profiling the sides. Tomorrow I begin fitting the back. Yeah, I'm slow, but better to take my time on these early ones than to add days by having to remake stuff!
Phil
http://www.oleninstruments.com
"Those who tilt at windmills are only considered insane by those who can't see the dragon."
PostPosted: Mon Sep 03, 2012 11:29 pm
First name: Patch
Last Name: Rubin
i started putting frets on my first.
this is one of those moments during the build where it starts to look like something. kind of like when the box gets closed or the neck gets fit for the first time.
http://www.wideskyguitars.com
https://www.instagram.com/wide_sky_guitars/
PostPosted: Tue Sep 04, 2012 3:12 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
I finished a bridge slotting jig and made a bridge template. On previous builds I have used pre-made bridges, but want to branch out into different woods, and to tweak the standard bridge design just a bit.
Also got the truss rod installed.
PostPosted: Tue Sep 04, 2012 7:58 pm
Last Name: Flindall
City: Peterborough
Beth - the timing of your post couldn't be better! I'm almost to the stage of needing to cut my saddle slot and have started thinking about how I'm going to go about making a jig to do that. Your pic has got me off to the races - thanks!
Rob
Rob Flindall
Flindall Guitars
http://www.flindallguitars.com
https://www.facebook.com/FlindallGuitars
PostPosted: Tue Sep 04, 2012 9:19 pm
First name: Patch
Last Name: Rubin
Rob
same here!
PostPosted: Wed Sep 05, 2012 3:48 pm
Last Name: Killin
I’m in the middle of my second fret install. This L-00 has almost taken 2 years to build and I’m excited to be so close to the end.
Next step will be saddle slotting and bridge install.
That is a good looking saddle slotting jig Beth. There is always a new jig to build. Can you add some details on the jig? Did you follow a plan? I can see that being a good weekend project.
PostPosted: Wed Sep 05, 2012 6:19 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Hey John, looks really nice!
I did not follow a plan. You sort of need to custom it for whatever plunge router base you have. The base is 1/2" MDF and is about 14 x 18. I jointed the edges of the plywood pieces that serve as a base rail of sorts (where the router base rides), and jointed the oak pieces that form the sides of the channel against which the router base rides. I just installed the 2 left hand pieces so that there is 1/2" plywood for the router to ride on and made sure the top piece is exactly square to my channel. Then just put the router up against that the way it will travel, and installed the other side's pieces the same way, making sure the channel's sides exactly parallel eachother and will allow the router to ride without any slop and straight side to side. The stop blocks on either side are two layers of 1/2 MDF glued together and slotted. The shim angle was figured using a pre-made bridge and aligning it until the slot was the way I wanted, then using that angle. Pop a couple of large cork-lined washers on either end to hold down the wings and you're good to go. Have fun! Beth
PostPosted: Wed Sep 05, 2012 9:05 pm
Last Name: Killin
Thanks Beth. [:Y:]
PostPosted: Thu Sep 06, 2012 7:32 am
Three builds going, a BZ dred, and two OM's with double sides. Every flat surface has something on it.
The BZ is amazing, sent to me by the client who has had it over 20 years. Perfectly quartersawn and straight grained. Wild figure types would not like it.
PostPosted: Thu Sep 06, 2012 9:03 am
BZ= Brazilian rosewood, yes? Man, to get something that nice and straight these days is really something. Lucky you (and client)!
PostPosted: Thu Sep 06, 2012 10:15 am
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
that is nice!!!!!!!!!
MK5acoustics.com
