It is currently Thu Aug 21, 2025 5:49 am
Post new topic Reply to topic  [ 73 posts ]  Go to page 1, 2, 3  Next
PostPosted: Wed Aug 29, 2012 3:41 pm
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
Zip/Postal Code: 33634
I'm working on my first two builds (classical -two in case of the fatal flaw), and am ready to attach the sides to the tops. Next I'll be closing in the box, but just realized (better late than never) that I don't know if I need to finish the inside of the box in any way. What does anyone out there recommend? The tops are spruce and red cedar and sides and bottoms are zebrawood and mahogany, if that makes a difference. I've used spruce for braces and mahogany for kerfing. Thanks in advance for any advice!
PostPosted: Wed Aug 29, 2012 3:50 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
The overwhelming majority of makers do not finish the inside of the box. It certainly isn’t necessary and it could make future repairs difficult.
Bryan Bear PMoMC
PostPosted: Wed Aug 29, 2012 3:52 pm
I seem to recall there were at least a couple of threads on this. Below is one.
viewtopic.php?f=10101&t=25066&hilit=Taran+inside
PostPosted: Wed Aug 29, 2012 3:53 pm
Sandpaper, up to P240 at least.
PostPosted: Wed Aug 29, 2012 4:10 pm
First name: Big
Last Name: Jim
No .
PostPosted: Wed Aug 29, 2012 4:13 pm
I recently began shellacking the inside of the tops to see if it would help prevent the tops from moving up and down (changing the action) during RH swings. It made no difference...
PostPosted: Wed Aug 29, 2012 4:29 pm
yes, always, shellac
PostPosted: Wed Aug 29, 2012 4:56 pm
+1
Milton, ON
PostPosted: Wed Aug 29, 2012 5:07 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I can't fit my hand, and spray gun though the soundhole eek
Seriously, I have finished the inside with shellac a few times, but no longer do. I don't see any big drawbacks, but didn't think there was any advantages either.
PostPosted: Wed Aug 29, 2012 6:33 pm
No. It does little, if anything, to slow moisture exchange. It does however, hide glue squeeze-out that was not cleaned up very well. Many different opinions, though.
PostPosted: Wed Aug 29, 2012 6:42 pm
First name: Patrick
Last Name: Hanna
State: Missouri
I've seen this discussed and argued many times. I believe most makers don't apply a finish inside, as they are convinced this could make future repairs more difficult (I presume they are talking about gluing in cleats, replacing braces and so forth.
On the other hand, I can hardly believe that a thin coat of shellac sealer would be any more difficult to clean up than a failed brace glue joint or thirty years worth of dirt and oxidation. No matter what's inside the box, it must be cleaned up before a repair can be made.
I'm an archtop fan and I've watch Robert Benedetto demonstrate sealing the inside of his archtops with a thin coat of shellac, which he immediately wipes off with a paper towel. He will remove the backs of his instruments for repair work, whereas a classical builder will work through the sound hole if possible.
I am NOT arguing for an internal finish when I say all this. I'm just saying that I think a lot of people repeat what they have read, without having personal experience.
I don't have that repair experience. I've only got logic and an inquisitive mind. I would love it if an experienced repair person would chime in and detail this for us, and explain it once and for all. I would really listen to that. I really would, so I hope someone can definitively explain this. I'll be watching with you.
Patrick
PostPosted: Wed Aug 29, 2012 7:01 pm
this is one of those things that matters to those that do it but it only adds a cost to the construction and there is no real advantage to doing it.
PostPosted: Wed Aug 29, 2012 7:26 pm
First name: tim
Last Name: minkkinen
City: charlotte
State: nC
Zip/Postal Code: 28203
Country: united States
Shellac, yes. Makes a huge difference in humidity exchange. Taking a guitar from a controlled environment to a less controlled environment my last four guitars are much more stable than my first nine. Especially if you build in the southeast U.S., epicenter of humidity swings. T
PostPosted: Wed Aug 29, 2012 7:36 pm
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
Somogyi recommends a coat of shellac, but seeing as this is your first build, I'd think you have much bigger things to worry about :-)
Relax and think about it for number 10.
PostPosted: Wed Aug 29, 2012 9:54 pm
First name: David
Last Name: Malicky
Zip/Postal Code: 92111
The effectiveness of shellac would likely depend on whether it's waxed or dewaxed.
David Malicky
PostPosted: Thu Aug 30, 2012 12:59 am
How so David?
PostPosted: Thu Aug 30, 2012 1:04 am
State: Serbia
+1
PostPosted: Thu Aug 30, 2012 3:29 am
Country: Romania
I've added shellac to the inside of a few guitars because the customer requested it. It's sometimes useful to make things look cleaner but I highly doubt it helps much against low/high humidity. In terms of repairs, the wood should be sanded anyway as oxidized wood does not bond that well.
Build log
PostPosted: Thu Aug 30, 2012 5:55 am
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
All,
appreciate such prompt replys and suggestions. Charles T, thanks for the thread. Think I'll go with some additional sanding and leave it at that for now; I'm getting anxious to close the boxes and see how this binding thing goes.
Again, thanks everyone. [clap]
PostPosted: Thu Aug 30, 2012 6:06 am
Shellac is not water proof so if will allow water to pass. I don't see from an engineering standpoint other than looks. It may help for RH shock but not as a true moisture barrier.
PostPosted: Thu Aug 30, 2012 8:36 am
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
I have done it a couple of times, with shellac. It takes no time at all and costs very little. I think it makes the inside of the box look cleaner - especially with dark woods like walnut or rosewood. I am sure it does absolutely nothing for RH stability, sound quality or anything else except appearance.
PostPosted: Thu Aug 30, 2012 8:53 am
Shellac is one of the best vapor barriers we have. I'm still looking for the link but 3 coats of shellac beats just about everything when it comes to passing moisture.
I put about 3 coats of shellac on the interiors of my instruments now and I'm finding that rapid changes in humidity are more gentle on the instrument now. They still swell when it's wet but they now do so more evenly on the inside and out.
PostPosted: Thu Aug 30, 2012 9:03 am
Yay, after two years of re-googling I finally found the study I was talking about. http://www.fpl.fs.fed.us/documnts/fplrp/fplrp462.pdf
I was wrong about shellac being the best but it's still very good compared to most other finishes.
PostPosted: Thu Aug 30, 2012 9:05 am
I never have but I've always wondered if it would be better.
For those that say it won't make a difference? Why bother finishing the outside of the guitar then? idunno
Is finish really just to enhance beauty? Isn't it also functional too? Doesn't it slow the absorption of moisture into the wood?
PostPosted: Thu Aug 30, 2012 9:55 am
It certainly can depending on the finish.
The reason I finish the insides is to even out the absorption. Shellac is a wonderful moisture barrier and many of us use shellac as a base coat under other finishes (I do). After having some instruments go all pringly on my in high humidity environments I started shellac-ing the insides and it's made a difference. With shellac on one side and nothing on the other, you get quick moisture absorption on one side and slow on the other which can cause major distortion.
By sealing both sides with shellac, you're balancing out the absorption. If your finish is transparent to moisture, it will make much less of a difference. Check the link I posted above to see how your finish fares.
