It is currently Thu Aug 07, 2025 11:58 am
PostPosted: Sat Aug 25, 2012 11:55 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
Well I was sanding the neck that goes with this body
and I noticed that on the endgrain areas, it looks like there are resins coming up or something. I've heard of something like this happening with spanish cedar, but is this something that also happens with mahogany on occasion? I pore filled with eggwhites and the finish is KTM-9. Does anyone know what happened and any ways to fix it (preferably without stripping the finish)
PostPosted: Sun Aug 26, 2012 8:36 am
I have seen this from using CA on Mahogany. If you have not used it possibly your supplier may have to stabilize a crack. CA will often run through the pores sealing the wood in that area making finishing difficult to hide the glue print. You can try using a toner to hide it
In 12 years I have not ever seen this without a CA contamination .
PostPosted: Sun Aug 26, 2012 10:34 am
Last Name: Sonksen
City: PORTLAND
State: Oregon
Zip/Postal Code: 97216-2013
This looks similar to what's happened to me using tung oil on mahogany. It's usually from a pore that soaks up more oil than what gets on the surface, and then it bleeds back out. I'd guess those spots didn't quite get filled all the way.
PostPosted: Sun Aug 26, 2012 5:12 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Looks like the extractive bleeding I've seen on lots of Spanish Cedar. What species of mahogany is it? How hot are you getting it while sanding? Could it be Spanish cedar, which is a true mahogany after all. If it is sap bleed a good cleaning with alcohol will usually remove it.
Brian
PostPosted: Sun Aug 26, 2012 7:32 pm
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
I don't know but it looks to be happening in to many spots to be CA contamination unless they used it for multiple cracks and I don't see that. It may be the egg wash. Maybe a compatibility issue with the KTM-9 and egg whites.
Another day, another dollar.
PostPosted: Sun Aug 26, 2012 7:35 pm
It looks like Spanish Cedar.
PostPosted: Sun Aug 26, 2012 9:33 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
I've worked with quite a bit of Spanish cedar and this is definitely not SC. The grain and pore structures are different and it didn't have the horrible smell/taste that SC has.
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
BTW, I ended up stripping the finish and doing a refin on the neck.
PostPosted: Sun Aug 26, 2012 9:45 pm
And now our curiosity is aroused!
Pics please. And report--how did it turn out?
Way to hang in there,
PostPosted: Sun Aug 26, 2012 10:18 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
I have about 10 coats of KTM-9 on it and so far it looks good: I'll post some pics after it dries. I'm really hoping it works out.
PostPosted: Mon Aug 27, 2012 8:14 am
First name: Tony
Last Name: C
City: Brooklyn
It looks to me like that mahogany is sad and it's just crying a little. Maybe take it outside to play a bit and it will cheer up and stop crying. [:Y:]
http://www.CostaGuitars.com
PMoMC
PostPosted: Mon Aug 27, 2012 10:16 am
Last Name: Peck
City: Templeton
Zip/Postal Code: 93465
This problem is likely from mahogany harvested from young immature trees. Probably sourced from plantation grown trees that are less than 30 years old.
Lance Peck
PostPosted: Mon Aug 27, 2012 11:03 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Hey! SC smells awesome! pfft
I would not make a neck out it because of that tendency to make sap. But you would know if was because of that wonderful scent! :)
Did you use any oils on it?
PostPosted: Wed Aug 29, 2012 12:55 am
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
I simply refinished the areas that had the problem and blended the new and old finished: it worked well
PostPosted: Wed Aug 29, 2012 5:45 am
look much better
PostPosted: Wed Aug 29, 2012 7:08 am
First name: Tony
Last Name: C
City: Brooklyn
Nice job.
PMoMC
PostPosted: Wed Aug 29, 2012 7:16 am
well done.
Users browsing this forum: meddlingfool and 33 guests
