It is currently Wed Jul 23, 2025 1:12 am
 Post subject: Fingerboard thicknesses
PostPosted: Sun Feb 05, 2012 5:21 pm
First name: Virgil
Last Name: Mandanici
State: FL
Is there an industry standard as to how thick the fingerboard should be before putting on a radius - trying to set up my template pin on a shooting board to start slotting these these with a template from SM and wondered where you all have the thickness before doing so - I know putting a radius on there will bring this down slightly - just want enough room - excited to slot these on the table saw as opposed to the Japanese fret saw/ miter box which has been taking it's toll on my hands! I need to get this measurment to keep a "standard size" in my shop from here on out.
PostPosted: Sun Feb 05, 2012 6:01 pm
.250"
PostPosted: Sun Feb 05, 2012 6:40 pm
3/16ths or 1/4 inches, either one. Most custom guys use 1/4 inch.
Old growth, shmold growth!
PostPosted: Sun Feb 05, 2012 10:36 pm
First name: Virgil
State: FL
Thanks guys - that's what I had for my calculations and it looked like it would be 1/8" deep slot cut into the 1/4" board for the fret slots, which should fit the tang nicely after the 12" radius.
All in favor?
PostPosted: Sun Feb 05, 2012 11:41 pm
If your fretboard is 2.25 inches at the end, you will need to add 1/16th of an inch to the depth of the fret tang, which can vary. I measured a large fret and the tang was a little over 1/16. You may also want to add a hair to account for final sanding and/or inlaying and then sanding. I would say a slot depth of 5/64ths should be sufficient. You can always add depth if you need it, though.
PostPosted: Mon Feb 06, 2012 12:35 am
First name: Alex
City: Houston
Aye.
PostPosted: Mon Feb 06, 2012 1:03 am
First name: Virgil
State: FL
So, what do any of you do when you use the SM template with saw on the table saw to do your fret slots? Any formula? How deep are you all sawing the fret slots? I realize that they have to go deeper the farther up the fingerboard, but is this generally done by hand?
I'm looking at a way to streamline this a bit more - what do you think SM does?
PostPosted: Mon Feb 06, 2012 1:13 am
First name: Virgil
State: FL
I had heard a "certain" manufacturer of guitars simply went a little deeper and filled the extra bit of hole with CA.
PostPosted: Mon Feb 06, 2012 2:12 am
Well, most manufacturers slot them a hair deeper and fill the ends, with wood filler or CA. It's the fastest way.
If you want your slots to be exact depth, you can saw the slots on the tablesaw a little shallow, and use the depth stop on the StewMac fret slotting saw to set the final depth after sanding and radiusing, set exactly to the depth of the tang. Then it won't matter, they'll all be the same depth up the whole length of the neck. I used to do that on every neck, but frankly, I don't think the tone is affected if the fret slots are a little deeper than the fret tang.
PostPosted: Mon Feb 06, 2012 9:37 am
First name: Roger
State: Oklahoma
This is why I'm glad I've got a radial arm saw. I can radius first and then cut my fret slots beehive :D
I'd probably do like guitar whisperer said. Cut just shy and then finish by hand after radiusing. It won't be as streamlined as you want, but you'll get some great results
PostPosted: Mon Feb 06, 2012 10:58 am
First name: Virgil
State: FL
ACK! You YOUNG whipersnappers with your radial arm saws!
PostPosted: Mon Feb 06, 2012 11:45 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
What makes you think he is going to do any inlay work on the fretboard?
laughing6-hehe laughing6-hehe laughing6-hehe duh
PostPosted: Mon Feb 06, 2012 11:53 am
First name: Virgil
State: FL
I don't know Alan - I am planning on just putting ab dots on build #4! (And theguitarwhisperer offered to teach me how to put them in! laughing6-hehe )
PostPosted: Mon Feb 06, 2012 6:42 pm
Yeah man, if you need help with your dots, just lemme know.
PostPosted: Mon Feb 06, 2012 7:00 pm
First name: Virgil
State: FL
LMAO GW!
Actually, it's the simple things that screw me up!
PostPosted: Mon Feb 06, 2012 8:36 pm
First name: alan
City: Santa Rosa
State: ca
Don't laugh Virgil.
Try getting those stupid dots straight!!!!!!!!!!!!
PostPosted: Mon Feb 06, 2012 8:37 pm
First name: Mark
Last Name: Sorrentino
Don't laugh Virgil.
I'll second that.
PostPosted: Mon Feb 06, 2012 9:51 pm
Getting the dots straight is no problem if you install them while the fret board is unprofiled.
PostPosted: Mon Feb 06, 2012 10:00 pm
First name: Virgil
State: FL
Don't laugh Virgil.
I'll second that.
Who says I have to put my dots in straight?
{Insert evil laugh from Virgil here: :evil: laughing6-hehe :twisted: }
PostPosted: Mon Feb 06, 2012 10:09 pm
First name: Virgil
State: FL
I have never looked into actually inserting these abalone dots into a fingerboard that I purchased from SM, but I will bet anyone that the following way would work, and would never be questioned by a customer:
On scrap piece of wood, double check brad point drill has correct size hole for inlay dot.
Locate centerpoint of fretboard.
Mark point with scribe (Pushing into the grain)
Set drill stop, so it doesn't go through fretboard.
Drill holes
Use sledgehammer to pound the crap out of the abalone shell to fit into hole
Smear a gallon or so of CA glue all over dots
Run the whole thing through my planer to level.
Any questions? Probably not.
Finished.
PostPosted: Mon Feb 06, 2012 11:22 pm
First name: alan
City: Santa Rosa
State: ca
Questions?
Yes, I have one, um,,
oops, fergot what it was, dang!
PostPosted: Mon Feb 06, 2012 11:26 pm
First name: Virgil
State: FL
Questions?
PostPosted: Tue Feb 07, 2012 1:03 am
VirgilGuitar wrote:
Don't laugh Virgil.
I'll second that.
You know, i actually think that looks pretty cool.
PostPosted: Tue Feb 07, 2012 1:51 am
I like a Forstner bit better than a brad point.
PostPosted: Tue Feb 07, 2012 12:19 pm
First name: Mark
If a gallon is not enough you can thin it down with another half gallon or so of mixed epoxy. Make sure you cover the front and the back of the fretboard or you'll get Tone Seepage.
Also, don't forget to tape aluminum foil to the back of the fretboard before you glue it onto the neck, so you can protect the truss rod from harmful radiation from power lines.
