It is currently Sat Aug 02, 2025 11:28 am
Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2
PostPosted: Sun Aug 28, 2011 1:41 pm
First name: micah
Last Name: medlong
City: parma
State: ohio
Zip/Postal Code: 44129
getting the money to buy the tools I need gaah
PostPosted: Sun Aug 28, 2011 8:12 pm
First name: Jim
Last Name: Kirby
Gluing in individual tentallones on classical builds!
(I'm cheating now and gluing in broken off segments of kerfed linings, a la Somogyi and others.)
Making sure the neck angle is right on Spanish heel builds before gluing on the back. Most recent one was dead on, but I never seem to believe it until the saddle is shaped and the 12th fret action is measured.
Jim Kirby
kirby@udel.edu
PostPosted: Mon Aug 29, 2011 9:39 pm
First name: Patrick
Last Name: Hanna
State: Missouri
Lots of the building steps are tedious for me, but most of those are challenging. The part that I really and truly wish I could just make go away is trimming the overhangs off the top and back right after the box is closed. Man....I just hate that part. There is nothing about it that I find gratifying or exciting. It's just pure unadulterated tedium to me.
PostPosted: Mon Aug 29, 2011 10:55 pm
A quick lap around the guitar with a laminate trimmer and flush-cut router bit and the job's done, with the proviso that you climb-cut where appropriate. What's tedious about that? ;)
Pete
PostPosted: Tue Aug 30, 2011 4:39 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
CAJUAN wrote:
I used to hate making fret slots, until I bought a Proxxon Fet tablesaw. Now, I only hate sanding the guitar before finishing.
Could you clarify what is a Proxxon Fret tablesaw?
I might get one sometimes... which model is it exactly?
Typhoon Guitars
PostPosted: Tue Aug 30, 2011 6:24 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Seriously though, I think the most painful aspect of guitar building, aside from fretwork, is finishing.
Typhoon Guitars
PostPosted: Tue Aug 30, 2011 8:18 am
For me it's finishing by far. I really do hate it. I've used water base for ten years now and I still have yet to get it just right. I'm going to do my first French polish in a couple weeks.
Alain Moisan wrote:
Fitting the neck joint. Specially on classicals and flamencos where the surface is quite round. Less painfull on OMs and Dreadnoughts where the neckblock area is almost flat.
(Yes, I use a bolt-on neck joint for my classicals and flamencos, for those wondering...)
Just did that last night on my current flemenco. Assuming like me you do not have a tenon joint I get it real close with a chisel and rasp and then I use an arched sanding block. If necessary I'll finish it off by double stick taping a fresh piece of 60 grit to the body and a few strokes and she fits like a glove.
PostPosted: Tue Aug 30, 2011 2:32 pm
First name: Jim
Last Name: Hansen
I don't do my own finishes, and probably never will. If I had to do my own I would probably not build at all.
Outside of finishing, my biggest trepidation is probably routing truss rod slots and accurately cutting the mortise and tenon on the neck block and neck. For some reason these processes feel foreign to me and I'm having difficulty getting comfortable doing it. I need to find a way to practice doing this without worrying about screwing up a guitar-in-progress....
Jim Hansen
PostPosted: Tue Aug 30, 2011 2:58 pm
First name: Corky
Last Name: Long
City: Mount Kisco
I hear you.
Robby Obriens got a great toot on routing the Mortise and tenons. Requires a bit of jig building, but looks pretty sweet. (no, I haven't built that jig yet) - still experimenting on my process.
As for routing the truss rod slot, I use a router mounted upside down in my workbench and pass the neck along a simple fence that I've clamped to the table - adjust the router a little higher after each pass (and make a mark on the neck so I stop the tress rod routing at the right place. Works for me.
PostPosted: Tue Aug 30, 2011 3:01 pm
First name: Corky
Last Name: Long
City: Mount Kisco
the Padma wrote:
Well me biggest pain was when me lost the tip of me left thumb at the table saw ripping neck blanks.
The others are minor like when the chisel slips when rabbiting and me gets to really feel just how sharp it is.
The other real hassle, although not a pain, is when the CA runs and me digits fuse together.
blessings
Ouch - wow7-eyes
table saws scare me. I know that vigilance is critical with all those tools, but I jsut get a bad feeling about table saws. Too many of those stories.....
PostPosted: Thu Sep 01, 2011 11:37 am
First name: frans
Last Name: van duuren
City: breda
State: noord-brabant
Country: netherlands
Although it's my second one; the most difficult part of acoustic building is to fix a stable neck/body joint.
The neck always seems to bow to the body under string tension (mortise tenon bolt-on ) duh gaah
Don't worry be happy.
PostPosted: Thu Sep 01, 2011 12:11 pm
Sanding and Pore filling, by far.
PostPosted: Thu Sep 01, 2011 12:16 pm
I hate installing side dots on the FB. I end up sanding a prety steep angle into the board when shaping the neck so I don't want to do it before and no matter how careful I am centering my starting hole I am always nervous.
Burton
Brookline, MA.
PostPosted: Thu Sep 01, 2011 12:22 pm
First name: Miguel
Last Name: Bernardo
Country: portugal
http://www.amazon.co.uk/Proxxon-fine-table-saw-Fet/dp/B0029W0Y1C/ref=sr_1_1?ie=UTF8&qid=1314897619&sr=8-1
so far, i´ve enjoyed most of guitar building. cutting the peones (dentellones, tacos) is a bit tedious, though.
PostPosted: Thu Sep 01, 2011 1:06 pm
Last Name: Kincheloe
You can speed up the process a lot by splitting rather than sawing most of the surfaces. Square up a stick of spruce, about 1x1 - 1.25x1.25". Cut off a square from the end, the width you want your dentellones. It will make 16 dentellones.
First, split the square in two down the middle, then split each of those two down the middle, so you have 4 little sticks about 1x0.25". Sand the split surfaces smooth, with a few rubs on 60 grit and then 100 grit (you can arch them for better mating to concave curves at this point, getting 2 for the work of 1 :) )
Then split each of those 4 sticks in two, so you have 8 little rectangles. Sand the split surfaces again (arching again while you're at it, if desired... see notes later). Then split each of those diagonally, and you're done. No need to clean these surfaces, as they're not glued to anything, and the split grain looks cooler in there (not that you can see it without a mirror anyway :P )
And now, about the second optional arching. Using flat topped dentellones on a dome topped guitar tends to crimp the top flat at the perimeter, especially around the waist when using flat rims, as is typically done in this building style. Angle topped dentellones can help support the dome, so on the split surfaces that you have to sand anyway, you can make some variable angles for different areas of the top. If you want to angle all of them a little bit, you can just change the shape of the long stick that you cut squares from to start with, so each square (actually parallelogram now) is split up like this:
But it's still handy to be able to do some variable arching on the split ones you have to sand anyway. Might even need some flat ones for the neck joint area, depending on your neck angle.
PostPosted: Thu Sep 01, 2011 1:09 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Can someone enlighten me as to what a peone is?
Typhoon Guitars
PostPosted: Thu Sep 01, 2011 1:51 pm
Notching linings for top and back braces tops my list, with a very close second going to finishing.
Freeborn Guitars
and home of BeauGuard©
PostPosted: Thu Sep 01, 2011 5:39 pm
I use an extremely sharp awl to make a pilot point for my drill bit.
Old growth, shmold growth!
PostPosted: Fri Sep 02, 2011 8:29 am
First name: Corky
Last Name: Long
City: Mount Kisco
Yeah, true - that's a pain. I don't seem to be able to do that very precisely. My linings always seem to have gaps around the braces.
PostPosted: Fri Sep 02, 2011 10:17 am
First name: Hugh
City: Lake Oswego
State: oregon
I've spent so much time trying to improve my least favorite step that I've started to like it. What step that is migrates around the guitar.
PostPosted: Fri Sep 02, 2011 10:22 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I think the greatest pain when building the guitar is playing it. I can't play guitar to save my life and so even though I build such a good guitar, I can't play it.
Typhoon Guitars
PostPosted: Fri Sep 02, 2011 4:30 pm
First name: Nils
Last Name: Johnson
City: Boston
State: Massachusetts
Nice, tight and completely flush neck joint.
Patience is really hard too.
PostPosted: Fri Sep 02, 2011 8:11 pm
Yes.
PostPosted: Fri Sep 02, 2011 8:41 pm
Sharpening plane irons and chisels, probably because I don't have good sharpening tools.
Final sanding of the body and getting it all ready for finishing is probably my least favorite task.
Users browsing this forum: Bing [Bot] and 40 guests
