It is currently Sat Aug 09, 2025 5:35 am
PostPosted: Mon Oct 31, 2016 1:17 am
I have a new nitrod guitar with a small problem. I had someone do some finish touchups, unfortunately, there is now buffing compound in a clear distinct white line buried in the neck to body joint. I want to remove the compound without harming the finish.
Any ideas?
PostPosted: Mon Oct 31, 2016 5:35 am
Maybe a little warm soapy water and a small brush?
PostPosted: Mon Oct 31, 2016 6:57 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Naptha
Brian
PostPosted: Mon Oct 31, 2016 7:06 am
Even better!
PostPosted: Mon Oct 31, 2016 12:01 pm
Hmm. Th bloody elusive in Canada naphtha.
I think' have a squirt of ronsonol somewhere...
PostPosted: Mon Oct 31, 2016 12:09 pm
lighter fluid is naphtha. Any white gas is darn close too.
PostPosted: Mon Oct 31, 2016 1:15 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
A damp cloth and a sharpened toothpick should be enough to do it.
PostPosted: Tue Nov 01, 2016 11:47 am
Naphtha is what we used in production at GM
Ken Cierp
PostPosted: Tue Nov 01, 2016 2:07 pm
State: ON
Just so you know, Naptha is available in Canada. Mowhawk finish products sells it by the gallon and it is availible through Richelieu. Richelieu only sells to businesses, but if you don't want to go through the trouble of setting up an account then every cabinet maker and most general contractors probably have one. I get mine through a contractor friend in town. This is also how I get my Nitro.
http://www.richelieu.com/ca/en/category/woodworker-essentials/finishing-touch-up/mohawk-finishing-touch-up/reducers-solvents-and-additives/naphtha/1020842/sku-M6500047
Josh
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Tue Nov 01, 2016 3:35 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
I set up a cash/credit card business account with Richelieu last week, with no problem. If you want an account to carry a credit balance, you have to jump through the usual hoops. Price is $46.21/gal.
Alex
PostPosted: Tue Nov 01, 2016 6:04 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
Stick-type compounds employ a wax-like base to bind the bar together and allow application to a spinning buff. Naphtha is the correct solvent for that binder as suggested by several gentlemen here, and will not harm lacquer. When a thin line of compound is packed into an open seam or undercut corner, some mechanical assistance may be required, just as Mr. Arnold points out above. We use thin, flexible wooden coffee stirrers reshaped to a smooth, sharp chisel point to gently remove dead buffing compound from around the bridge, pick-guard, and other nooks and crannies.
- Beth Brower
PostPosted: Tue Nov 01, 2016 6:55 pm
First name: Cal
Last Name: Maier
City: Crossfield
State: AB
Ed, Mohawk has two stores in the Vancouver area. They should have naptha.
Cal
PostPosted: Tue Nov 01, 2016 7:04 pm
Thanks folks!
Users browsing this forum: Bing [Bot] and 43 guests
