It is currently Tue Aug 05, 2025 11:15 am
PostPosted: Fri Feb 25, 2005 11:55 am
Here's a tip I just discovered for all those of you who use circle cutters to do rosettes and such.
When I was at Frank Finnochio's class I noticed that he had a number of cutters for his circle cutter that had different thickness for the different purflings and inlays he uses.
When I got home I went down to Woodcraft and sure enough they had the replacement cutters for around $8.00 apiece. Seemed a little high to me.
I was looking through Grizzly's big catalog a few days ago in the reading room and found that they had tool steel bits for a metal lathe that had a little cobalt added for durability. They happened to be exactly the same size as the cutters I needed. And they were only $1.95 each.
I reground and sharpened one up today and was very happy with the cut I was able to get with it. I ordered several of them on my last order, so I'm gonna grind them to the various thicknesses I need and I will be able to just swap a cutter and inlay the b/w/b lines or whatever....
Hope this is of some use to someone.
PostPosted: Fri Feb 25, 2005 12:26 pm
Describe how you resize them Dave. TIA
PostPosted: Fri Feb 25, 2005 1:18 pm
I just ground them down om=n my bench grinder (carefully, and dip them in water to keep them cool), then sharpened them up on the Tormek.
I grind mine so there is a back angle and only th very front edge is doing the actual cutting.
PostPosted: Fri Feb 25, 2005 4:21 pm
I do this with my ukes (they all have different soundhole sizes and rosette
outside diameters. I just buy the $8 fly cutter from home depot or
whatever and get the bits and grind them to what I need. I've also see
guys take a spade bit and grind it down to cut a three ring rosette in one
shot with a simple fly cutter and a spade bit really ground and modified.
It worked really well.
PostPosted: Fri Feb 25, 2005 8:07 pm
Spade bits, man that's amazing John. and cool.
PostPosted: Fri Feb 25, 2005 11:12 pm
John, the nice thing is, for the price that you are paying for a new circle cutter - just to get the bit - I can buy 4 of these bits and grind them all to different profiles.
The grinding only takes about 5 or 10 minutes since they are relatively small. You might even be able to use it as is, since it does come with a slight bevel already ground into it.
PostPosted: Mon Feb 28, 2005 4:40 am
I'm not sure if we're talking the same type of cutter here, but here's what I do. The photo shows two different bits and how I ground them. At places (like MSC?) the bits are about a dollar each.
PostPosted: Mon Feb 28, 2005 6:02 am
Yeah Pete, that's the idea! Looks like you've found an even cheaper source than I did. Thanks for the info!
PostPosted: Mon Feb 28, 2005 11:53 am
No I'm not using it just to get the bit. On my ukes there are 4 different
soundhole sizes, and likewise 4 different rosette diameters. I use a
separate one for each. I don't care about the money. I care about the
time it takes to change it for each one. That way I just swap the cutter to
match the model. Much less set-up time and time is money.
PostPosted: Mon Feb 28, 2005 12:09 pm
That makes sense. Thanks for the clarification.
