It is currently Wed Apr 29, 2026 7:28 pm
 Post subject: Machining thin wood
PostPosted: Tue Mar 03, 2015 9:04 pm
First name: Daniel
Last Name: Henriks Madureira
Country: Close to the great white north
Hi everyone,
Quick question:
How do you machine, say... a headstock veneer?
Let's say I have a part that's 1/8inch thick and I want to do a 0.080 in pocket for some inlays... No vacuum available.
Aside double sided tape...any ideas?
Mind you that it's wood...if it was plastic I could glue it to a sacrificial plate, and then boil the whole thing to remove the small pieces...
CNC is a tool, not cheating :)
 Post subject: Re: Machining thin wood
PostPosted: Tue Mar 03, 2015 9:11 pm
Oh cnc. Got it!
PostPosted: Wed Mar 04, 2015 11:18 am
Vacuum
PostPosted: Wed Mar 04, 2015 12:20 pm
You've eliminated the two best options. Either use vacuum or double-sided tape. I agree with Andy though. Tape is problematic.
The only other choice is using locators and clamping, but you have to clamp as close to the pocket as possible. Just get a vacuum pump and make a fixture.
PostPosted: Wed Mar 04, 2015 1:07 pm
You could make a full face clamp with the pocketed area cut out of it. You'd have to index it into the proper position with locating pins. That is assuming the pocketed area is not some large percentage of of the face.
PostPosted: Wed Mar 04, 2015 7:00 pm
Dan I think tape is the best
Get a long spatula to remove it
It's no problem if you're really careful.
And I just use the shelving board from Home Depot with the white melamine cover it's extremely flat takes tape very well
Ken
Ken
PostPosted: Wed Mar 04, 2015 7:52 pm
First name: kevin
Last Name: waldron
City: Bell Buckle
Zip/Postal Code: 37020
Sacrifice board, hide glue, newspaper, hide glue, part/part's...... use Clothes Iron or use Micro-wave on defrost to release.
Blessings,
Kevin
PostPosted: Wed Mar 04, 2015 8:54 pm
First name: Daniel
Thanks for your replies everyone.
Definitely vacuum is on my bucket list, but for a one-off part it's kind of overkill for me at the moment. I'm actually in the process of designing a few different vacuum fixtures for multiple applications.
I think i'm going to try two options... Ken's suggestion, and Kevin. Didn't thought about the shelving board, I have a few off cuts here :)
I also like the newspaper trick.
I'll post a couple of pics once I machine the part.
Thanks guys!
