It is currently Mon Sep 15, 2025 12:18 pm
 Post subject: Fretboard side markers.
PostPosted: Thu Jul 12, 2012 9:36 am
First name: Dan
Last Name: Bennett
City: Suwanee
State: Ga
Zip/Postal Code: 30024
I am installing fretboard side markers on a completed Strat neck. ( Customer is using a right handed neck on a left handed guitar) I know I need a fence of some sort to maintain a uniform line. What are you guys using? Pics?
PostPosted: Thu Jul 12, 2012 11:04 am
I laid out some tape, measured carefully, and drilled carefully to install the dots.
Had my apprentice spot me to make sure I was perpendicular to the neck.
Took an hour.
PostPosted: Thu Jul 12, 2012 11:44 am
First name: James
State: Maine
I just measure for the center of each side fret area and use something fine to make an impression (I often just use a wood screw) and then put the neck in a drill press vice and drill each centered indent. My side dots are usually 3/32" from the neck/fretboard seam.
PostPosted: Thu Jul 12, 2012 4:49 pm
First name: Mark
Last Name: Sorrentino
Yup, that's pretty much it. Cept I never used a drill press, just marked em with a punch and drilled carefully. Worked for me, seem pretty straight.
PostPosted: Thu Jul 12, 2012 9:10 pm
I believe the fence is most usefull when against the back of bound but not yet installed fingerboards, keeping the dot drilling in line & a fixed distance (I use .100") from the underside. (This is not necessarily centered vertically in a constant radius fingerboard, as the edge thickness changes). I always found slight wandering the issue, so I now use 3/32" twist drill I ground into a sharp brad-point that I use just for this.
Keeping a neck rigid while drilling is more important than a fence once the neck is together IMO, since the drill line doesn't remain a constant distance from anything "fenceable" anymore, unless you register off the frets.
Milton, ON
