It is currently Tue Sep 16, 2025 1:42 pm
PostPosted: Thu Jun 30, 2011 11:12 pm
First name: Alex
Last Name: Takacs
State: Illinois
I've been building cigar box guitars for about a year now and I decided that it was high time I build an actual guitar! Im making a telecaster neck through design with a soft curly maple neck, honduran mahogany wings, and Ill be putting some walnut burl veneer over the mahogany on the face of the guitar only. Ive got a compound radiused ebony fretboard from stewmac. Im going to arm this monster with a floyd rose two p90s (maybe the seymour duncan p-rail p90/single coil/humbucker in the bridge http://www.seymourduncan.com/products/e ... ils_shpr1/ ). I know that p90s and a floyd dont really go together, but I figured Hell, I want p90s and I want a floyd rose so why not slap both on a tele! Ive Actuall gotten through a good portion of the build already, im currently just about ready to start rounding the neck. Lemme know what you think or if you have any suggestions! -Alex
Last edited by WindyCityBluesBox on Sat Jul 02, 2011 8:12 am, edited 2 times in total.
PostPosted: Thu Jun 30, 2011 11:14 pm
First name: Alex
Last Name: Takacs
State: Illinois
Heres the raw materials
Cut the mahogany into wings
Veneered the mahogany
Last edited by WindyCityBluesBox on Thu Jun 30, 2011 11:16 pm, edited 1 time in total.
PostPosted: Thu Jun 30, 2011 11:15 pm
First name: Alex
Last Name: Takacs
State: Illinois
Trimmed the veneer off of the sides and belt sanded to smoothness :)
PostPosted: Thu Jun 30, 2011 11:27 pm
First name: Alex
Last Name: Takacs
State: Illinois
coming together
PostPosted: Thu Jun 30, 2011 11:30 pm
First name: Alex
Last Name: Takacs
State: Illinois
Got a rough cut on the body, needs a little sanding
Routed the neck for a single action truss rod and two carbon fiber rods. I accidentally let the wood jump of the fence once or twice when routing for the carbon fiber rods, but it will fill with some epoxy no problem before the fretboard goes on. I routed the truss rod slot deeper in the middle to accommodate a curved truss rod.
PostPosted: Fri Jul 01, 2011 1:48 am
First name: David
Last Name: Morris
City: McKinney
Good work. Yeah, those slips can be fixed easily. Want to know a trick? If you wrap your truss rod in plastic wrap before you glue down the fret board. it will make for a tighter fit, and also prevent future rattling!
David Morris
PostPosted: Fri Jul 01, 2011 10:35 am
I like the veneer on the mahogany.
Keep the pics coming!
Old growth, shmold growth!
PostPosted: Sun Jul 03, 2011 12:51 pm
That's an abomination, alright! An abominably good one! I likey! A lot!
PostPosted: Sun Jul 03, 2011 3:39 pm
First name: Alex
Last Name: Takacs
State: Illinois
By now Ive tapered the neck and glued on the scarf jointed headstock. Ive got to do some re-routing through the headstock and I gotta say its really kickin my a**. Right now im just takin a break before I go out and do some more. Excited to finish the routing!
PostPosted: Sat Jul 09, 2011 9:44 pm
First name: Alex
Last Name: Takacs
State: Illinois
I routed this space out for the wires to run through from the pickup cavities and go to the control cavity, but inforunately I discovered that this particular cavity will not work with the floyd cavity so its gotta get filled!
I cut and sanded some mahogany then glued it into place. Here it is after snading. Fits like a glove!
PostPosted: Sat Jul 09, 2011 9:50 pm
First name: Alex
Last Name: Takacs
State: Illinois
I tapered the neck and attached the headstock blank. The headstock blank is two pieces of scrap curl maple that I had from the neck (not book-matched) and I re-routed the slots for the truss rod and carbon fiber rods through the scarf joint
Here is is with the truss rod and carbon fiber rods in the neck. You can see marks on the headstock where the router bit skipped across when I was routing the cavity for the truss rod nut. In this pic it is filled with epoxy. I will soon be putting some burl veneer over the front of the headstock so this little mistake will be hidden :)
PostPosted: Sat Jul 09, 2011 10:01 pm
First name: Alex
Last Name: Takacs
State: Illinois
Part of one of the carbon fiber rods was sitting a hair about the neck. The rod was in there to tight to pull out so I just tapped off the neck with painters tape and took a little bit off the top of the rod with a dremel.
This is the piece of wood that I'll be cutting up to be the strip that I use to glue in the truss rod. It is a piece of padauk I had laying around and it was JUST the right size. Its pretty Ironic because I wanted somethind like padauk or hard maple on top of the rod to brighten up the sound of the guitar a little bit (probably makes an almost un-noticeable change in the sound but I still wanted it :) )
Here it is fresh off the table saw and ready to go!
After cutting the rod to length and threading it, I put some JBweld on the rear threads of the rod and on the slug (which I ground the top off of to let me get more of a curve) to keep them from un-screwing.
PostPosted: Sat Jul 09, 2011 10:21 pm
First name: Alex
Last Name: Takacs
State: Illinois
Tomorrow I should be able to glue on the wings!
