It is currently Sat Jul 26, 2025 8:22 pm
PostPosted: Tue Nov 08, 2005 1:35 am
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Zip/Postal Code: 98506
Well, by the end of this weekend I'll have two dreadnought boxes together, and I've been thinking about the neck - specifically the neck angle and using routing templates. I'm going to build a jig to use with StewMac templates, and was wondering if I should build in a 1 1/2 degree angle per the MacRostie plan or should I build the jig perpendicular to the plane of the top of the neck and use shims to achieve the appropriate angle? Or do I just rout the tenon at 90 degrees and then tweak the angle with hand tools. I plan on building nothing but dreads for a few years, so it is unlikely the neck angle will change.
How are you all doing it?
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Tue Nov 08, 2005 1:47 am
My thoughts are to adjust by hand. but many have good results pre setting. To me those little finite tasks are among the things that I really enjoy doing. Neck angle sets, inlay cutting and channeling, brace carving...Heck!!!! come to think of it I love all luthierie
PostPosted: Tue Nov 08, 2005 12:12 pm
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Found some great info on this in the archives!
I WILL read the archives before posting. I WILL read the archives before posting...
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Tue Nov 08, 2005 12:20 pm
I know you are thinking about a non adjustable jig, but you should check out the jig of Paul Woolsons. Once it is adjusted for a Dread you will not have to reset it, but in the off chance that you ever make another type of guitar it will easily accomadte it.
PostPosted: Fri Nov 11, 2005 12:25 am
Brock,
forgive my ignorance, but where can I find Paul Woolson's adjustable neck
jig?
Craig
PostPosted: Fri Nov 11, 2005 12:49 am
Hi Craig
It is in this thread.
Neck Jig
PostPosted: Fri Nov 11, 2005 4:27 am
Thanks. That's a great looking jig. I have something similar, but mine is
rigid for one angle only. Being able to adjust it makes it so much better.
So many jigs to build -- so little time!
Craig
