It is currently Sun Jul 27, 2025 12:10 pm
PostPosted: Sun Oct 02, 2005 3:50 pm
Hey folks, I just got back from a weekend in the BC outdoors and found this lying in the bush.
Have any of you used antler before?
Would I treat it the same as bone? Boil the heck out of it and notify all the neighbours when I cut it.
PostPosted: Mon Oct 03, 2005 12:27 am
I am no expert but having made a knife handle from wite tail antler I would think it to porous for nut and saddle material.
PostPosted: Mon Oct 03, 2005 1:14 am
I have experimented with Moose antler (I can get truckloads of the stuff) and have found it to soft and porus, muffled the sound.
PostPosted: Mon Oct 03, 2005 5:03 am
Rod, you might be able to use it. I would try cutting some-- that should indicate if it is hard enough.
I have a question about boiling it, though.
Is that standard practice? I would think (and mercy, I could be WAY off) that boiling bone--for instance--would drive the fats further into the material?
I'm just asking, because I really don't know how the big shops process the material we use.
I have soaked bone chunks in bleach, which has to be monitored, or it will make the whole piece too "chalky".
Anyway--this could be a fun project. And since you found the antler, you won't be out too much money!
PostPosted: Mon Oct 03, 2005 8:19 am
I think that's a great suggestion Steve, Just give it a try, got nothing to loose.
I will look at it under the magnifyer to see if I can see any difference between cow bone, doubt I can, but hey, why not. Maybe I could build a woodsman guitar, locale woods, with the antler nut and saddle as the feature.
PostPosted: Mon Oct 03, 2005 9:14 am
Sure--or just do the "file test".
If it's hard like ivory or bone, you're good to go.
I like the idea of a guitar using local woods.
And YOU are in a great place to do it!
PostPosted: Mon Oct 03, 2005 11:20 am
First name: Coe
Last Name: Franklin
City: Decatur
Rod, I just got some bone nuts and saddles today from Sam`s over in Taiwan. He set me up with a couple extras if you need `em. He said buffalo, I`m presuming water buffalo. Can`t remember proper name for that critter.
Can anyone tell me if there`s a way to sort out good from bad? Do I really need to concern myself with the subject? I do notice a "grain" in them, and color is pretty consistent, for the most part.
PostPosted: Mon Oct 03, 2005 1:44 pm
I've used antler for cane handles and I too think it is too porous for nut and saddle. You might fill the pores with CA and make it work.
