It is currently Thu Aug 14, 2025 9:01 am
PostPosted: Sat Nov 17, 2007 7:50 pm
I need a good tutorial on how to put a cream binding on my neck.
and what tools I will need.
PostPosted: Sat Nov 17, 2007 8:51 pm
Glue it onto the sides of the fingerboard after slotting and radiussing, and before gluing it to the neck shaft.
Tools needed: whatever you taper your fingerboard with (say, a plane), some glue (medium or thick CA is what I tend to use), a chisel if you want to mitre the ends, a bit of masking tape, and a scraper and/or sandpaper and/or finger plane to trim it to size.
Process: taper, fit mitres, glue binding on (hold in place with tape), let dry, trim (scrape/plane/sand), glue down, level fingerboard, fret.
And you'll want one of those handy dandy fret tang nippers (StewMac has 'em) to snip the tangs off the fret ends, otherwise fretting becomes a major pain.
PostPosted: Mon Nov 19, 2007 10:07 am
First name: Hank
Last Name: Mauel
Zip/Postal Code: 95603
OR...
You might want to route in a rabbet to the tapered fingerboard and set the binding in that. It gives you a nice, thin line of exposed fingerboard wood along each side of the fingerboard and sort of a delineation line between the neck shaft and the binding.
See the following photo for an example of koa on an ebony fingerboard:
Hank Mauel
PostPosted: Mon Nov 19, 2007 10:25 am
[QUOTE=MickeySpringer]I need a good tutorial on how to put a cream binding on my neck.
I tie a traditional windsor knot........
Sorry - couldn't resist - welcome to the OLF!!
PostPosted: Mon Nov 19, 2007 12:27 pm
Hesh, you have that 70's look going on with the cream tie. Bet you got the matching cream colored socks and platform shoes to go with it too?
