It is currently Mon Aug 04, 2025 11:42 pm
PostPosted: Wed Oct 10, 2007 1:38 am
I have been using the truss rods that are accessable through the sound hole in the body, but I would like to try my luck at the ones that are adjustable through the headplate.
Are there any differences in the rods?
Some pictures on how to prepare the neck for these type of rods would be nice to see !!
Also, I am particularly interested in truss rods that dont weigh as much. The ones I have been using weigh a ton and I would like to lighten the neck if possible. Any suggestions?
PostPosted: Wed Oct 10, 2007 2:23 am
Ken, two way rods can do either.
I use LMI's compression rod which is lighter in weight. It is accessible from the headstock.
PostPosted: Wed Oct 10, 2007 4:08 am
City: Lawrence
Zip/Postal Code: 66047
Bruce, Do you remember the Archtop that Matt brought to Beebe. Now that was a very neat way of adjusting the truss rod.
PostPosted: Wed Oct 10, 2007 5:24 am
First name: Martin
Last Name: Edwards
I've only eve accessed the rod from the soundhole once.
it seems a lot simpler to just run the slot out the end of the neck at the headstock end.......
PostPosted: Wed Oct 10, 2007 5:29 am
Gibson style requires special neck channel and slot but a most modern truss rods just require that you cut the channel till it exits the peghead.
PostPosted: Wed Oct 10, 2007 7:17 am
The reason I am asking is that I am building a little maple OM right now and I would like to put in several smaller sound holes instead of one big one. Because of that, it would be impossible to reach the truss rod from the body end.
PostPosted: Wed Oct 10, 2007 7:31 am
Last Name: Walden
City: Bartlesville
State: Oklahoma
Zip/Postal Code: 74006
Another way is to put a removable plug at the end block.  I think that GAL/American Lutherie has a tutorial in one of the issues within the last couple years.
Steve Walden
Aspiring Builder,
Bartlesville, OK
PostPosted: Wed Oct 10, 2007 7:58 am
Yes Dave, that was a beautiful guitar and innovative approach to adjustment. Ball end T-wrench if I remember correctly. Slot up the headstock with veneer front and back.
PostPosted: Wed Oct 10, 2007 8:17 am
I make Gibson style rods for my guitars from 3/16" SS rod, accessible from the headstock. There is nothing lighter.
