It is currently Mon Aug 04, 2025 10:44 am
PostPosted: Sun Jul 15, 2007 11:20 pm
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
Question..
If one uses addi -split into straight-Why can't one use 1/4" bracing. Addi is strong and it is my basic understanding that strength of the brace is produced mostly by height. So, why not?
PostPosted: Sun Jul 15, 2007 11:25 pm
   I see no reason that you can't. Martin has been using 1/4 sitka bracing for years. Look at the D35.
john hall
PostPosted: Sun Jul 15, 2007 11:44 pm
Yep, Martin do it and as long as the brace is tall enough to be structurally sound why should there be a problem. After all, given the compounding effect of strength to height ratio one could very easily over build with 1/4" braces.
PostPosted: Sun Jul 15, 2007 11:58 pm
This is an interesting idea.
PostPosted: Sun Jul 15, 2007 11:59 pm
The widest braces I use (only go up to OM/OOO) are 6mm for the X and upper tone bar, the rest are only 5mm. I usually use Euro spruce for my bracing.
PostPosted: Mon Jul 16, 2007 12:05 am
Bob...I've used 1/4" bracing on 7 guitars that included Parlors, OM's, 000's and SJ's. Height has varied depending on top stiffness and voicing choices.
In general, we rookies tend to over-brace.
PostPosted: Mon Jul 16, 2007 10:12 am
Remember... the strength increases linearly for increases in width and x^3 for increases in height.
PostPosted: Mon Jul 16, 2007 2:39 pm
Todd is pointing out a very important point, the stiffness is what increases with the cube of the height which is not the same thing as the strength of the material.
PostPosted: Mon Jul 16, 2007 4:41 pm
[QUOTE=Jim_W] Todd is pointing out a very important point, the stiffness is what increases with the cube of the height which is not the same thing as the strength of the material.[/QUOTE]
You're right... inaccurate choice of words.
PostPosted: Mon Jul 16, 2007 10:40 pm
Last Name: Johnson
State: CO.
Thanks for all the great info!!
