It is currently Wed Jul 30, 2025 8:22 am
PostPosted: Sat Apr 14, 2007 10:11 am
Is there a method for "welding" plastic binding, by which I mean melting
two pieces into each other so that the seam is either non existent or at
least invisible? Heat doesn't seem to do the trick, wondering about
acetone, though I have it in my mind that's just for celluloid.
PostPosted: Sat Apr 14, 2007 11:06 am
State: ON
The best thing to do would be to give it a try and see what happens. Do you have some scrap pieces that you can test this on? Let us know how it works.
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Sat Apr 14, 2007 11:57 am
Last Name: Abercrombie
Stewart-MacDonald sells a jig (which you could make if you are handy) for laminating plastic bindings together, using acetone.
Instructions are on the website:
http://www.stewmac.com/shop/Bindings,_trim/Tools_and_supplie s_for_binding/1/Binding_Laminating_Jig/Instructions/I-4200.h tml#details
If the link doesn't work you can just follow your nose at the stewmac website and find the info.
Hope this helps.
PostPosted: Sat Apr 14, 2007 1:37 pm
First name: Jim
Last Name: Kirby
What John said. You can also do a butt joint that way too.
You can dissolve binding scraps in acetone and use the resulting white goop as a filler too.
For dark bindings (tortoise), thick or medium CA works well enough as a gap filler.
Jim Kirby
kirby@udel.edu
PostPosted: Sat Apr 14, 2007 4:40 pm
I use the same plastic melted in acetone and smear it in the middle of the
join. Thinking of carpentry, I'd mitre the joint, like you would for
baseboards or moulding end-to-end. For some reason, it flows better and
the melted plastic doesn't have as big a job to do.
Users browsing this forum: Bing [Bot] and 8 guests
