It is currently Tue Jul 22, 2025 3:35 am
PostPosted: Thu Mar 15, 2007 4:48 pm
I have no idea how to charge for inlay. Here is the lay out.
The inlays are about $35.
PostPosted: Thu Mar 15, 2007 5:27 pm
Well, I have no answer to your question -- but I really like the design you
have there. The different orientations of the same inlay shape is very well
done.
Peace Out,
Simon
PostPosted: Fri Mar 16, 2007 12:39 am
First name: Craig
Last Name: Lavin
City: Sunrise
State: Fl
Zip/Postal Code: 33323
Is the question how much should I charge for insetting these and finishing them - given they are costing me $35.00 from the inlay cutter source pre-cut?
Or is it - I designed these- they are costing $35.00 in pearl - per ounce, and I still have to cut them out, and finish the job.
It really depends on a lot more than the price of the pearl.
Craig L
www.handcraftinlay.com
PostPosted: Fri Mar 16, 2007 3:02 am
[QUOTE=clavin] Is the question how much should I charge for insetting these and finishing them - given they are costing me $35.00 from the inlay cutter source pre-cut?.......
That's the question.
Thanks you for the needed clarification Craig.
PostPosted: Fri Mar 16, 2007 4:20 am
    I price my inlay trying to figure $50 an hour labor rate. I double up my pearl when I cut using rubber cement , then separte them with solevent. I think you should be able to cut them out in less than an hour so say $75 for pearl and labor
Inletting that may take a bit of time. Also about 1 hour so $125 is not too high for that layout.
john hall
PostPosted: Fri Mar 16, 2007 4:39 am
Steve,
I’m certainly not a pro but based on my first attempt at inlay I would charge plenty. Just inlaying a Paua letter on a test piece of wood makes me respect anyone who can do it well. At this point I will be satisfied if the inlay is even somewhat acceptable
My advice is don’t sell yourself short. Your work and your extra effort should be compensated appropriately.
Philip
aka konacat
PostPosted: Fri Mar 16, 2007 4:42 am
That looks very simular to one I did last year.
I charged more than tippie's quote, but I also have the snakewood vine in there too. The price was also lumped it in the the rosette and some other inlay on the headstock, so I am not exactly sure how it broke out pricewise. I also cut my own inlays, so material cost was relativley low, but the time labor time was higher.
Where I quoted this job low, was in design time. The guy I made this for did change is mind a lot during the design and that took more time than actually implementing it.
PostPosted: Fri Mar 16, 2007 6:27 am
Very nice Johno.
PostPosted: Fri Mar 16, 2007 7:16 am
I think for the type of inlay we're talking about, an hourly rate makes the
most sense. If you were going to put position markers on the fretboard
anyway.... the added charge would only be for the extra time needed for
making the recess a different shape.   I hope this makes sense.
Long
PostPosted: Fri Mar 16, 2007 7:44 am
If I charged the "hourly rate" I normally get making guitars then it would come to around $10 in total
Jon - I'm not usually a big fan of fingerboard inlays but that is really lovely. I think the snakewood vine is just sublime
