It is currently Fri Aug 01, 2025 2:00 am
PostPosted: Thu Dec 21, 2006 10:38 am
Thanks for sharing your procedure Todd. I'm not sure if you seen this before, but here is a link to Pegasus Guitar (Bob Gleason) showing his similar method of producing triangular kerfed linings.
kerfed lining
PostPosted: Fri Dec 22, 2006 12:32 am
First name: Jim
Last Name: Kirby
Todd -
Thbis is one case where I have to say "Thank God for our vendors"
Merry Christmas.
Jim Kirby
kirby@udel.edu
PostPosted: Fri Dec 22, 2006 3:44 am
I make mine like Bob Gleason shows, only I use a single blade, and I plane the final facet on the linings like Cumpiano shows in his book; with a block plane against a straight edge. Like Todd, I find it is an excellent way to use up mahogany scraps...
PostPosted: Sun Dec 24, 2006 4:56 am
So sorry to be late on this one, thanks Todd, i am one of those who enjoy giving me pain so i'll do it your way instead of mine which was more painful ie one at a time!
Merry Christmas bro!
PostPosted: Sun Dec 24, 2006 6:34 am
I made some once and it was fun but not a profitable thing in my case but I do admit , once you start the final stages it is fun to see the pile grow.
THanks for sharing
john
PostPosted: Sun Dec 24, 2006 4:49 pm
Todd,
Thanks for showing how you make your linings. It's not something everyone prefers to do, but I don't mind making my own.
This is how I make my Triangular Linings. My photos arn't near as good as yours so please excuse.
1st I thickness plane the board to 5/8" and rip it into strips on the tablesaw. I run those through the planer to end up with final deminsions of 5/8" wide X 7/32" thick
Next I place a table in the planer that has a slot cut in to accept the lining strip and hold it in the correct position.
I then start running the strips through the planer to get the shape of the lining.
After getting the strips to this point I start runnung them through the kerfing sled.
I end up with kerfed linings that are clean on the side glue surface and the showing surfaces without having to clean them up any further.
Anyhow, this is how I make them. And again, please excuse the poor quality photos.D.L.Huskey39076.0398263889
PostPosted: Mon Dec 25, 2006 4:19 pm
Todd, I have some WRC linings milled but haven't used any of them yet. To me they seem a little brittle for linings. I have been using harder woods like the mahogany, walnut, and have used maple cherry and black-gum.
The wood in the photos is eastern red cedar or eastern juniper. I want to see if it will be suitable for linings.It seems to be a little stronger wood than WRC.
The blade I use for this is a 10 T.P.I. Raker tooth. I tried the Skip and Hook tooth blades but the top of the kerf looked wavey. The finer tooth blades do a much better job for this. D.L.Huskey39077.0147453704
