It is currently Thu Aug 21, 2025 6:44 pm
PostPosted: Tue Sep 19, 2006 12:18 pm
Can anyone tell me the advantages of having a variable speed router vs. fixed. I am looking at the P.C. 7518 and 7519. Both are 31/2hp why or on which woods would I use a slower speed? TIA
PostPosted: Tue Sep 19, 2006 1:28 pm
First name: Louis
Last Name: Freilicher
City: Belchertown
State: MA
Zip/Postal Code: 01007
I always use mine set for fast with the LMI pattern routing but in a
router table. The slower speeds would be needed for larger diameter
molding and raised panel bits. A larger bit diameter means that the
bit is moving faster at the cutting edge thus the need for speed
reduction at the motor. Hope this helps.
Louis
- Louis Freilicher
PostPosted: Tue Sep 19, 2006 1:53 pm
slower speed also required when doing aluminium, plastics, etc.
PostPosted: Wed Sep 20, 2006 12:18 am
Thanks guys!
PostPosted: Wed Sep 20, 2006 9:58 am
First name: Louis
City: Belchertown
State: MA
You're welcome Dave. BTW I love my PC7518. It's mounted in a
home build router table and it has worked like a champ.
Louis
- Louis Freilicher
PostPosted: Wed Sep 20, 2006 12:00 pm
First name: Nelson
Last Name: Palen
Variable speed is for when the kids are sleeping.
Nelson
PostPosted: Wed Sep 20, 2006 3:08 pm
One reason for running a router slower is to reduce burning.
Some woods - cherry, for example - burn easily if you move the router too slowly when making a cut. If you run the router bit slower, you can move the router slower also, without burning the wood.
Phil
