It is currently Sun Jul 27, 2025 10:53 am
PostPosted: Sat Sep 09, 2006 11:53 pm
Some time back I bought some of the tool box drawer lining material to use as a pad on the work bench. Covered the whole top with it and it worked pretty well.
Then one day as I was spraying a guitar body, after letting the 1st coat set for a few minutes, I go back and have fish-eyes all over the top and back.
I tried a second coat but they popped right through.
Next day I took the body down to bare wood and started over, same thing happened. After the 3rd time I finally got it sprayed. This happened on two different guitar bodys.
Now fast forward a little, I was sanding on another body which I left lying on the bench for a couple of hours while I left the shop. When I got back and picked up the guitar I was working on, to my surprise, it was covered with oily looking spots in the same pattern as the pad material.
Oil? Silicon? I don't know but the material came off and the carpet went back down onto the bench. No more finish problems of this type have happened since it's removal.
While I was reading Hesh's post about Necks and seeing his photos reminded me of my delimma with this padding.
I won't use this padding anymore except in the tool-box, and maybe it's not all bad for wood. But I'm not taking any more chances.
Just thought I would pass this along.
D.L.Huskey38970.3729861111
PostPosted: Sun Sep 10, 2006 12:02 am
D.L., This is what i use, it's got a perfectly flat side and all cushiony and a rough surface on the other side so it doesn't slip off the workbench, easy to store if they're in your way and easy to clean with the shop vac or a damp cloth.
PostPosted: Sun Sep 10, 2006 12:11 am
Yeah, those soft, sticvky rubber pads look like they'd be ideal for us, but they are a nightmare waiting to happen. Silicone, or something similar, must be used as the release agent in their casting, which causes the fisheye problems. The plastisizers in the rubber itself can react with finish(the fresher, the more likely the reaction), also.
I think we've all tried them at some point <sigh>
I wouldn't even use them in my tool box, since if it is a silicone, it will get on the tools, and can transfer to yuor hands, which can lead to the most frustrating of al finish problems; the random fisheye.
I just buy large, fluffy towels, and use them on the benches; get the blems at one of those discount stores.
PostPosted: Sun Sep 10, 2006 12:24 am
Thanks for the heads up on this... I used those in my dishes during brace carving, since it grips the top/back nicely while in the dish. I think I've done enough sanding since to eliminate any finish problems, but now I'll be double sure to get a clean fresh surface before I start FP'ing.
PostPosted: Sun Sep 10, 2006 12:30 am
I've heard it called plasticizer migration. It's what makes vinyl murder on nitro. Also makes that film inside your car windows.
PostPosted: Sun Sep 10, 2006 12:42 am
I use these pads. In fact, I have a large roll of the stuff (bought it either at Costco or Sam's, don't remember which), and cut pieces of it off for use as needed.
I've heard of this problem before -- I believe it was Mario who brought it to my attention, cautioning me against the use of this material. Heheh, by that point I'd been using the pads for quite a while. No problems here. But then, I use french polish, so I'm wondering if 1) whatever it is these pads give off doesn't affect the fp process, or 2) perhaps I got lucky and the material I bought doesn't have the chemicals that are giving you guys problems?
Best,
Michael
Live to Play, Play to Live
PostPosted: Sun Sep 10, 2006 2:50 am
No problems here either but if, as Mario mentionned, problems occured to people, i'll be more careful not to suggest those, there are so many other solutions out there anyway and fluffy towels sounds cool! Serge Poirier38970.4939351852
[QUOTE=Mario]I think we've all tried them at some point <sigh>
I just buy large, fluffy towels, and use them on the benches; get the blems at one of those discount stores.[/QUOTE]
This is what the forums are good for. If someone has a bad experience they can share the info and help the next builder. No matter how trivial the info may be.
It's been a year and a half or two since I used these pads. Had I saw Mario's warning about it, I would have been a lot more cautious about using them.
When I saw Hesh's photos it just reminded me why I don't use it for padding.
PostPosted: Sun Sep 10, 2006 3:25 am
Some time back I placed a finished guitar on one of the same pads, and it was a couple of days before I went back to the shop. The pattern had transferred to the lacquer. I figured that I could polish it out. Nope it didn't work. Next I tried steel wool, and shot a new top coat...Still there. Next I finally completely stripped the guitar then refinished it. I gathered up my bench pads and threw them in the trash. Haven't used one since.
PostPosted: Sun Sep 10, 2006 3:28 am
Yes, FP shellac isn't much bothered by silicone and plastisizers, usually. I'd also suspect that not all of these pads contain it, but, how to tell...
Big 'ol beach towels never cause problems <bg>
PostPosted: Sun Sep 10, 2006 3:52 am
The local farm and ranch had a sale on saddle blanket pads a while back back. Perfect size for a benchtop. I don't like the idea of mixing wood with plastic.
PostPosted: Sun Sep 10, 2006 4:31 am
D.L. Thanks for starting this post. I was eyeing those pads pretty seriously. Now I know better. And in line with what Mario said, Ikea has big fluffy terry cloth bath mats that would be perfect.
Thanks for sharing guys.
PostPosted: Sun Sep 10, 2006 4:34 am
I also use an old bedsheet that I've folded up a few times so it will fit on my work bench. When it starts getting full of sawdust or the occasional drop of glue, I'll just refold it so a new side is out. Lasts a long time between washings this way.
Best,
Michael
PostPosted: Sun Sep 10, 2006 5:00 am
Very valuable information, Thanks!
PostPosted: Sun Sep 10, 2006 9:31 am
yeah, if it's silicone, it migrates, and has a half life of a gazillion years.
PostPosted: Sun Sep 10, 2006 9:44 am
Mine are heading out to the dumpster tonight! Thanks
PostPosted: Sun Sep 10, 2006 10:26 am
Similar results here. I noticed it was leaving a pattern on unfinished spruce that had to be sanded out. Taking no chances on that. Now I just lay a cotton towel in my sanding dish.
BobK38970.8113310185
PostPosted: Sun Sep 10, 2006 12:39 pm
I use the carpet sample pads. You can get em for $1 each at a carpet store. Two of them is about the perfect gutar size.
PostPosted: Sun Sep 10, 2006 2:30 pm
[QUOTE=Serge Poirier] Mine are heading out to the dumpster tonight! Thanks[/QUOTE]
Nooooo! Go back to the dumpster and retrieve them! Those thick pads like you were using are meant to go on the floor. Put 'em by your machines and work stations and give your tired feet someplace cushy to stand while you're working! It really helps.
PostPosted: Sun Sep 10, 2006 2:41 pm
[QUOTE=CarltonM] [QUOTE=Serge Poirier] Mine are heading out to the dumpster tonight! Thanks[/QUOTE]
Nooooo! Go back to the dumpster and retrieve them! Those thick pads like you were using are meant to go on the floor. Put 'em by your machines and work stations and give your tired feet someplace cushy to stand while you're working! It really helps. [/QUOTE]
Just in time Carlton, i was getting up to go and throw them out for tomorrow's trash and read your post!
Thank you my friend!
PostPosted: Tue Sep 12, 2006 2:17 am
Dang, I was wondering about that. I have a walnut back sitting on one right now. I plan on FP'ing so hopefully I'm ok.
Thanks for the tip.
Horton, MI
