Solely owned and operated by Lance Kragenbrink
It is currently Fri Aug 17, 2018 10:25 am
PostPosted: Thu Oct 26, 2017 1:57 pm
First name: David
Zip/Postal Code: 94558
What might be everyones preference? If you could please explain why as well so I have a better understanding.
https://www.instagram.com/dofthesea/
PostPosted: Thu Oct 26, 2017 2:34 pm
Unslotted
If you're on FB here's a link with pics -https://www.facebook.com/a2guitars/photos/a.102289403211488.2853.100681526705609/102289456544816/?type=3&theater
“There are two men inside the artist, the poet and the craftsman. One is born a poet. One becomes a craftsman.” - Emile Zola
These users thanked the author Colin North for the post: Hesh (Thu Oct 26, 2017 3:12 pm)
PostPosted: Thu Oct 26, 2017 2:37 pm
I like unslotted. IF you keyhole the pin holes, which you should, then you don't need a slot in the bridge pin. THe unslotted pin holds the string in the keyhole ramp and slot and the ball end rests right on the plate where it belongs.
PostPosted: Thu Oct 26, 2017 3:15 pm
Or, in other words cheap, mass produced slotted pins have been damaging bridge plates since some corner cutting sort invented them to save on semi-skilled labor at the factory....
We have 1870's Martins with unslotted pins with virtually zero wear on the bridge plate because of unslotted pins.
I'll add that 3 degree is more desirable as well over 5 degree also because more string ball ends up firmly on the bridge plate not the edge of the hole in the bridge plate.
PostPosted: Thu Oct 26, 2017 3:45 pm
I prefer unslotted, spotted pins :)
These users thanked the author SteveSmith for the post (total 2): Bryan Bear (Fri Oct 27, 2017 9:51 am) • Hesh (Fri Oct 27, 2017 12:44 am)
PostPosted: Thu Oct 26, 2017 4:40 pm
First name: David
Last Name: Riedmiller
State: WI
Makes sense, Hesh. So those of us (me being one) with an abundant supply of slotted pins need merely turn them 180 after re-cutting the string slot?
"It is easier to fool a man, than it is to convince him that he has been fooled"
Mark Twain
These users thanked the author Rocky Road for the post: Hesh (Fri Oct 27, 2017 12:46 am)
PostPosted: Thu Oct 26, 2017 11:19 pm
Last Name: Kincheloe
I wouldn't. Assuming the guitar will change hands a few times throughout its existence, one of the owners will most likely turn the pins around "the right way" and then the bridge slots will accelerate the wear process.
These users thanked the author DennisK for the post (total 2): dpetrzelka (Fri Oct 27, 2017 12:25 pm) • Hesh (Fri Oct 27, 2017 12:46 am)
PostPosted: Fri Oct 27, 2017 12:49 am
Hey Rocky! I wouldn't and agree completely with Dennis. Because the top, plate and bridge are now slotted (once it's converted to unslotted pins) if someone did turn the pin around to utilize the slot it would be very damaging to the bridge plate because it's now double slotted. I know in your example that you are intending that the instrument doesn't change hands but what if it does for some unforeseen reason?
You are correct though that turning around the pins is a fix provided that no one ever doesn't understand why the pins are turned around.
PostPosted: Fri Oct 27, 2017 5:35 am
Anybody ever just filled the slots in the pins? Should be fairly simple I would have thought.
These users thanked the author Colin North for the post: Bryan Bear (Fri Oct 27, 2017 9:52 am)
PostPosted: Fri Oct 27, 2017 9:55 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I haven't yet but I have several sets of slotted ebony pins that I intend to do just that. I haven't settled on the moste efficient/effective way to do it yet. It could be one of those things that takes too long to get it to look nice making it not worth the effort. But I have the pins already. . .
Bryan Bear PMoMC
PostPosted: Fri Oct 27, 2017 9:59 am
First name: Brad
Last Name: Combs
All this talk about saving the bridge plate but we're missing the obvious advantage of unslotted pins.... it's the tone, man! beehive
"Is this the one where I trot downfield and act like I'm lost ?" - Billy Bob
PostPosted: Fri Oct 27, 2017 10:13 am
"Anybody ever just filled the slots in the pins? Should be fairly simple I would have thought."
I do - I just cut thin strips of corian and glue them in. You can also do this to tighten up a set of pins for slightly oversize holes. Cheap plastic pins have tested to be tonally superior to most other materials. [headinwall]
These users thanked the author Clay S. for the post: Bryan Bear (Fri Oct 27, 2017 10:26 am)
PostPosted: Fri Oct 27, 2017 10:35 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I'm glad you said that Clay. I was envisioning all the effort it would take to get the filler to match the cone of the tapered pin. My reasoning was that if it were flat across it would take away some of the advantage of it being unslotted and it would encourage people to line the filler strip up with the string. I now realize that having the strip slightly proud, would force the strip to be aligned with the string (keying into the string slot in the bridge) but also help keep the string ball pushed up against the bridge plate.
I haven't thought this idea through too much; it could be all wrong. Thoughts?
Bryan Bear PMoMC
PostPosted: Fri Oct 27, 2017 10:43 am
Trouble maker....;)
I just bought a Jimi Hendrix "authorized" Fuzz face pedal, does this mean I will play and sound and even look just like him? ;)
These users thanked the author Hesh for the post: bcombs510 (Fri Oct 27, 2017 11:20 am)
PostPosted: Fri Oct 27, 2017 10:55 am
Hesh wrote:
Trouble maker....;)
Do you like it? I've been looking for a pretty serious fuzz pedal for a while. I like my Big Muff but I also want to get that nasty, TheStooges, style fuzz that makes your guitar sound like it's cooking bacon.
PostPosted: Fri Oct 27, 2017 11:01 am
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
+1
PostPosted: Fri Oct 27, 2017 11:06 am
jfmckenna wrote:
Hesh wrote:
Trouble maker....;)
Yeah it's pretty radical and I do like it. You have to disconnect the input cable though or it eats batteries. I just got Lindy Fralin pups on my strat too and they are killer!
These users thanked the author Hesh for the post: jfmckenna (Sat Oct 28, 2017 10:41 pm)
Users browsing this forum: Bri, johnparchem and 13 guests
