It is currently Wed Apr 29, 2026 8:45 am
PostPosted: Thu Jan 26, 2017 2:20 pm
First name: Linus
City: Brooklyn
Zip/Postal Code: 11215
I'm wrapping up a tele build for myself. I made the body from scratch but am using a cheap Chinese neck that feels great.
I've had a custom water slide decal made and want to put a thin finish over it.
Because it's a cheap Chinese tele neck I assume the finish is catalyzed polymer. I dropped on some lacquer thinner and it's not reactive.
My question: after I apply the waterslide decal, what finish can I put over the decal to seal it in? What will be compatible with the finish that's on there? Can I shoot a light coat of rattlecan nitro? What do you recommend and why?
PostPosted: Thu Jan 26, 2017 3:35 pm
Yes Nitro will work.
PostPosted: Thu Jan 26, 2017 3:36 pm
Last Name: Beaver
City: Lake Forest
It sounds like one of those 'who knows until you try it' situations. Nitro most likely won't work but, the only chance you would have is to sand the surface, Spray vinyl sealer then nitro. Probably a waste of time.
If it was me I'd sand to bare wood and start over. If you are just doing a head Plate it won't be a big deal.
Joe Beaver
Maker of Sawdust
PostPosted: Thu Jan 26, 2017 4:02 pm
Last Name: Cox
Test in an out of the way non-show area...
PostPosted: Thu Jan 26, 2017 7:22 pm
Shellac sticks to most finishes.
PostPosted: Fri Jan 27, 2017 8:22 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Nothing will stick long term without proper prep and sanding of the current finish, after that any type of clear coat should hold. Bigger problem I have these days is what doesn't eat water-slide decals......The Glycols that have replaced the HAPs do not get along well with the gel the decals are made of and they either lift, melt or the clear part turns hazy.
Brian
Users browsing this forum: No registered users and 323 guests
