It is currently Tue May 26, 2026 5:58 pm
 Post subject: Tut for soundport?
PostPosted: Tue May 26, 2015 1:41 pm
City: Escondido
Zip/Postal Code: 92029
I've been building for about a decade now, but I've never cut a soundport. I was asked to cut a soundport into my next build and suddenly realized I'm not sure how that's done.
Is it cut before bending the side, or after? Is it reinforced somehow on the inside? If so, how?
I don't suppose there is a tutorial somewhere documenting the process, is there?
Thanks.
 Post subject: Re: Tut for soundport?
PostPosted: Tue May 26, 2015 3:09 pm
First name: David
City: Napa
Zip/Postal Code: 94558
Most people reinforce the interior of a sound port with a bent piece of wood matching the interior radius. I typically cut the sound port after the box is enclosed.
PostPosted: Tue May 26, 2015 3:30 pm
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=25805&p=347681&hilit=sound+port#p347681
Here's a past thread that has some useful information for you.
These users thanked the author SteveSmith for the post: Glenn_Aycock (Wed May 27, 2015 7:07 am)
PostPosted: Tue May 26, 2015 4:26 pm
I did an oval soundport after the box was closed, using a set-up like this http://www.luthiersforum.com/forum/download/file.php?id=15283&t=1, but using a guide bush in the base of my (smallest) router, so the template was oversized.
Reinforced the side behind the area with crossgrained veneer before the box was closed.
PostPosted: Tue May 26, 2015 5:40 pm
Have not done any sound ports, but use 1/64" aircraft plywood to reinforce on-board pre-amp control box cutouts. Strong and flexible.
http://www.nationalbalsa.com/birch_ply_p/1641224bp.htm
Ken Cierp
PostPosted: Tue May 26, 2015 6:51 pm
City: Escondido
Thank you all for your help. Consensus seems to be laminate a reinforcement on the inside, bend, then cut with router/coping saw/Forster bit.
Any reason not to cut while the side is still flat? That seems easier.
PostPosted: Tue May 26, 2015 6:56 pm
I bend first then laminate the reinforcement
PostPosted: Wed May 27, 2015 6:57 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Here is one I added to a guitar. New construction would be very similar except I would bend, fit and glue my reinforcement pieces before closing the box and then cut the hole after.
http://howardguitars.blogspot.com/2015/ ... uitar.html
Brian
PostPosted: Wed May 27, 2015 7:19 am
I always cut mine flat first and then bend the side. My main reason is that I bind my soundports and it's just a whole lot easier to do so flat rather than trying to get a good 3d bend.
These users thanked the author Pwoolson for the post: Bryan Bear (Wed May 27, 2015 9:29 am)
PostPosted: Wed May 27, 2015 9:31 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
What do you glue the binding in with? I'm surprised that the seam from one end of the binding to the other doesn't open up when the side is stretched and compressed into the bend. Do you do a scarf joint there? What part of the hole do you put this joint? I would guess one of the endgrain sides would have the least distortion. . .
Bryan Bear PMoMC
PostPosted: Wed May 27, 2015 1:21 pm
I've learned from that one. I do make a scarf joint at the widest part of the oval. I then make a tight fitting plug to fit into the hole before bending. The tight bond does loosen but once cooled it is back to solid. With the plug in place, nothing moves to where it shouldn't.
These users thanked the author Pwoolson for the post: Bryan Bear (Wed May 27, 2015 1:22 pm)
PostPosted: Wed May 27, 2015 1:24 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Is the plug side thickness and glued in? You wouldn't have a photo would you? That might save me from asking several more poorly formed questions. . .
Bryan Bear PMoMC
PostPosted: Thu May 28, 2015 7:45 am
I don't think I have a photo that I can think of. I can try to remember to snap one next guitar.
But to answer your question, yes, the plug is full thickness/depth. In fact, I often just use the hole cutout piece. If I use a 1/8" bit to cut the hole, it usually fits nice and snug once binding/purfling is in the hole. If it is a bit loose, I just shim the edges with some binding tape.
It's not really rocket surgery. You just need something to hold everything in place while the glue cools back down.
These users thanked the author Pwoolson for the post: Bryan Bear (Thu May 28, 2015 8:02 am)
PostPosted: Thu May 28, 2015 8:02 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Thanks!
Bryan Bear PMoMC
Users browsing this forum: No registered users and 84 guests
