It is currently Wed Jun 10, 2026 5:36 am
 Post subject: Two piece side question
PostPosted: Mon May 25, 2015 2:20 pm
I need to make a set of sides be a little bit wider. I was thinking of sawing down the middle and gluing a 3/4" piece of ebony in the middle between the two halves. Could Titebond III or some other water resistant glue be used that would survive the bending process?
I think I have seen a picture of this somewhere. I am hoping the collective wisdom of this forum will provide some insight.
PostPosted: Mon May 25, 2015 3:11 pm
First name: Tom
Last Name: West
State: Nova Scotia
Check out Howard Klepper's "Dovetail Madness".
Tom
PostPosted: Tue May 26, 2015 11:53 am
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
You can get an extra 3/16" at the top & bottom by gluing the linings that much proud of the sides.
A strip down the middle has a good chance of looking bad, unless the depth is the same at the neck and heel.
You can probably work out the geometry so that it looks OK, but it is something to consider.
PostPosted: Tue May 26, 2015 4:33 pm
Hide glue will take a lot of heat, unless you use water in the bending process. Failing that powdered resin glue (urea formaldehyde) can take serious heat and it's not affected by water, which is why it's used by the boat builders. In fact I'm pretty certain it has no known solvent. It's also plenty strong enough too.
PostPosted: Wed May 27, 2015 9:52 pm
Here's a picture of two piece sides I made for a Terz guitar currently in progress:
I glued the pieces together with the Lee Valley cabinet glue. The pieces are zebra wood and bubinga. I wasn't sure how the joint would stand up to the bending process but there was no problem at all. In fact, on one of the sides, I positioned the board about 1" out of place on the bender so I had to re-position it and heat it up a second time to get the waist in the right place. Again, no problem. So based on this I would say to give it a try.
PostPosted: Thu May 28, 2015 6:41 am
Pat,
Your experience is encouraging. I have never heard of Lee Valley Cabinet maker's glue until now.
PostPosted: Thu May 28, 2015 5:06 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Steve Frady wrote:
Pat,
I've been using it for close to 20 years, for cabinetry. I used it a couple of times for guitar repairs without any problem. It's called 202GF.
Alex
