It is currently Fri May 15, 2026 7:40 pm
PostPosted: Mon Jun 01, 2015 8:50 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
I realize that this is not an acoustic, but there's a lot more traffic over here & I'm desperate.
In the rush of gluing this neck, I didn't realize that it wasn't properly seated. The tenon should be flush with the top all the way. As a result, the neck angle is too steep.
I used hide glue so the joint is reversible but I'm trying to figure the most effective way to get it apart. With moisture & heat, the joint should come apart pretty easily but I'm not sure on the best approach to getting moisture in.
I found this where they drill holes along the joint then start by injecting boiling water, removing it & and any glue that gets dissolved, then finish with steam.
http://www.premierguitar.com/articles/R ... Pauls_Neck
Since the tenon on my build is not properly seated, there is some space under it which may help with getting moisture in?
Here are some more shots
Any ideas?
Kevin Looker
I'm not a luthier.
PostPosted: Mon Jun 01, 2015 9:59 am
Kevin, you should be able to get that joint open easily just using a little hot water (small amounts to start). Or you could use steam around the end of the tenon and down in the pickup hole. Of course, it will swell the fibers.... And then slow down putting it all back. You can do it!
These users thanked the author Chris Pile for the post: klooker (Mon Jun 01, 2015 11:58 am)
Users browsing this forum: No registered users and 134 guests
