It is currently Thu Aug 14, 2025 4:21 am
 Post subject: Badly cupped fingerboard
PostPosted: Sat Oct 04, 2014 12:52 pm
I was preparing an ebony fingerboard blank for use on a guitar recently. It had grey streaks in it. So I decided to try some black fingerboard dye I just got from Stewmac. This stuff is actually labeled "Fiebing's Leather Colors". It turned the fingerboard a nice even black, but it also caused it to cup quite dramatically.
I'd like to know if anyone else has had a similar experience and what would you do to counter the cupping.
Max
Max Bishop
Brighton, Michigan
PostPosted: Sat Oct 04, 2014 1:03 pm
Wet the other side of the board. This would have been better done before applying the dye but nothing to lose in applying it now. When I glue a fretboard with HHG I always damp the top surface just before gluing the fretboard.
PostPosted: Sat Oct 04, 2014 3:17 pm
Let it sit for a while and see what happens...
PostPosted: Sat Oct 04, 2014 10:19 pm
Last Name: Vallandigham
City: Martinez
Whatever you do, don't try to clamp it flat...unless you want it to split all to hell. DAMHIK...
PostPosted: Sun Oct 05, 2014 9:36 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Has the fb been fully dimensioned? If it is still in the rough, you can rip it down the middle, plane the cupped surfaces flat, joint the ripped edges, and then glue them back together.
Alex
PostPosted: Sun Oct 05, 2014 6:19 pm
First name: Ringo
PostPosted: Mon Oct 06, 2014 8:15 am
Thanks for all your input.
Max
Max Bishop
Brighton, Michigan
