It is currently Wed Sep 17, 2025 8:17 am
PostPosted: Thu Sep 25, 2014 10:31 am
http://www.stewmac.com/How-To/Trade_Sec ... newsletter
Please don't think I am criticizing Dan's method!
This is posted to stimulate discussion about a very important part of guitar building.
I have my own strongly-held opinion and method, but I'll hold off for a bit.
PostPosted: Thu Sep 25, 2014 12:28 pm
First name: D
Last Name: S
I add tension to the rod and then flatten the neck surface.
I glue the fretboard and level it.
It's not so easy to flatten the surface when there is a hump in the middle.
Maybe this a good method.
wah
Wah-wah-wah-wah
Wah
PostPosted: Thu Sep 25, 2014 12:42 pm
Seems not unreasonable with a single action rod. But with a two way rod...
PostPosted: Thu Sep 25, 2014 1:15 pm
I like Dan's thought process, especially if he is using a single-action rod, which many people like.
He did mention his experience from a repair perspective on factory guitars, but his method isn't really applicable to factory methods, maybe it is.
I make necks two ways, with and without a truss rod, but I'll leave the non-rodded neck out of the discussion for now.
I glue a flat, slotted fretboard on a stout, uncarved neck, dead flat on the gluing surface. I glue with hot-hide glue, and it imparts a very small amount of back bow when it is dry. The fretboard is then arched & leveled dead flat, fretted, and the neck profile carved.
The strings under tension may pull a little up-bow, but normally it doesn't. The "pre-stressed" glue joint helps maintain a flat board.
The double acting rod can take care of it either way, with very little turning of the screw.
PostPosted: Thu Sep 25, 2014 1:16 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Ditto. I don't see this being necessary if you use a double action rod. Tell me if I am wrong, though! If I'm wrong, I don't want to stay that way.
PostPosted: Thu Sep 25, 2014 5:09 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
Doing the neck like Dan shows, would you ever actually need a dual action rod?
PostPosted: Thu Sep 25, 2014 5:29 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
One thing that occurs to me is that if you used fish glue instead of hot hide glue, you could get a lot more control over the initial bow in the neck, and gain a lot of working time, by supporting it at the headstock and the heel, rigging up a clamp to depress the center of the fretboard/neck assembly, and then just clamp up as normal with lots of cauls and G clamps.
PostPosted: Thu Sep 25, 2014 6:59 pm
First name: sam
Last Name: guidry
State: michigan
Country: us
I rally hate double action rods. They can rattle and the relief they add is more like a smiley face instead of gradual natural relief. As dan says, if you build the neck " right" you don't needma double action truss rod
PostPosted: Thu Sep 25, 2014 9:17 pm
this is nothing new. Been doing that for years and I agree that a 2 way rod is overkill.
PostPosted: Fri Sep 26, 2014 12:25 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
You do surprise me, John.
I don't recollect ever seeing this technique mentioned on any of your excellent videos.
PostPosted: Fri Sep 26, 2014 12:59 pm
I have chosen to use a 2-part rod, either single or double acting, for my necks.
As a guitar repairman since 1975, the greatest number of neck issues that I have experienced are Gibson necks with single action compression rods with an "S" curve in the fretboard.
PostPosted: Fri Sep 26, 2014 1:59 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
Maybe Gibson didn't install the fretboard the way Dan shows ...
John Greven, who also has a long experience of guitar repair and build, has just recently espoused the single action compression rod and abandoned the dual action rod.
