It is currently Mon Apr 20, 2026 9:26 pm
 Post subject: purple wood.
PostPosted: Fri Jul 11, 2014 7:11 pm
Last Name: Wilson
Country: Scotland
Hi all. I have just got hold of a bunch of reclaimed timber. It is window frame wood from a fancy old hotel that was demolished close to my home. The hotel was built in the woods around 1880 so the timber is atleast 135 years old. After cutting the end off a few pieces I think I have oak, mahogany, teak and something purple in 6-10 foot lengths. Some pieces are better than others but there is lots that looks in very good condition which I can use hopefully.
My first question is about the purple. The only thing that looks similar is purple heart. Some lengths have more of a browny purple tone and others are bright like the piece in the pic, weighs about the same as a medium to heavy mahogany. The thing is I would be surprised if there was much purple heart lying around scotland in 1880.. So is this some other wood??
my second question is about the strength of old wood. Can I use this for a neck or would I be better perhaps using it for inlays and sandwiched pieces to add colour?
I will start running them through the saw tomorrow and see exactly what I have but the purple bits have been a lucky find I think :-)
 Post subject: Re: purple wood.
PostPosted: Fri Jul 11, 2014 7:43 pm
Last Name: Peck
City: Templeton
Zip/Postal Code: 93465
I'm sure Purple heart was in EU in 1880, it is a rather common tree and would have been just as interesting then as it is now.
Lance Peck
PostPosted: Fri Jul 11, 2014 8:54 pm
Last Name: Wilson
Country: Scotland
Cool thanks, purple heart is what it'll be then. Got enough for around 15-20 necks in the purple I think.
Is it a suibtable neck material tho?
PostPosted: Fri Jul 11, 2014 9:25 pm
If it's Purple Heart, it's pretty heavy for necks!
PostPosted: Fri Jul 11, 2014 10:04 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
Zip/Postal Code: 37355
The Purple Heart I have is extremely dense and heavy. Supposedly turns a brownish color. But probably purple underneath still. Also causes allergies to some folks. I used a nice piece for a fretboard on a Uke. Came out real nice but I'm putting 20 coats of finish on it to seal it away. So nobody breaks out in hives or something.
PostPosted: Sat Jul 12, 2014 3:41 am
First name: s
Last Name: g
I've seen purple heart used as the central lamination in a 3 piece neck
http://fyldeguitars.com/custom_guitars/fanfret.html
PostPosted: Sat Jul 12, 2014 6:26 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
The purple heart I've worked with is about as dense as white oak, maybe a little heavier. Not as bad as the rosewoods, but much heavier than light Mahogany.
Kevin Looker
I'm not a luthier.
PostPosted: Sat Jul 12, 2014 6:45 am
First name: Michiyuki
Last Name: Kubo
State:
Country: Österreich
Amazing that it kept color. I have seen purple heart used as necks, bridges, back, sides, etc. Hardness is very high hitting a little under or around ebony. So a Fretboard wouldnt be a bad idea.
It must have been some hotel to use purpleheart as window framing !
久保
美智え
PostPosted: Sat Jul 12, 2014 7:24 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Purple steaks and even sections of timber are very common in Poplar here in the US and I would not doubt that applied to the EU as well. It is rather doubtful that the framing of a Hotel would have been done in tropical hardwoods so I even wonder about the Mahogany. I have seen old items made from walnut that through the processes of aging have come to resemble mahogany.
Brian
PostPosted: Sat Jul 12, 2014 8:53 am
Historically, and even in the present day purpleheart is used for ship building and rough construction, similar to ipe and other tropical hardwoods. The difficulties it poses working the wood has made it less popular for cabinetry, although I did once build a chest of drawers out of purpleheart.
PostPosted: Sat Jul 12, 2014 10:58 am
Last Name: Wilson
Country: Scotland
It was called the greenmount hotel and it was a very expensive. Sat at the top of the hill looking over the forth estuary toward Edinburgh. From what info I have found it was built with no expense spared and was like 5 star back in the day. A fire took out half the building in the 1980s and it was left derelict.
Its definitely purple heart, I Cut some up and geez thjs stuff is hard! Its kept its colour internally and only turned a dark brown on the outside. Looks like it was varnish to start then it was painted white about fifty times lol. All that paint has sealed in the flavour I guess lol.
Fretboards are a great idea btw, it seems very similar in properties to ebony but the allergic reaction thing will need some more investigation though. Thanks for all the info guys ;-)
PostPosted: Sat Jul 12, 2014 12:50 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
I don't think it's all that bad. Like a bee sting to some is just a mild annoyance. But to others it can be life threatening. I never noticed anything. But the little girl I'm building the Uke for has Asthma and allergies. So I'm burying it under a ton of true oil. I think she will be ok with it. But I looked it up and it does cause problems for some.
PostPosted: Sun Jul 13, 2014 3:43 am
Commonly dust/oils cause problems and contact with the solid wood less so, e.g. Pau Ferro fretboards.
But I have had a splinter from tropical hardwood ply in my finger, which caused a rather quick and nasty reaction, which was not an infection.
PostPosted: Sun Jul 13, 2014 6:24 am
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
Thanks Colin;Wikipedia wasn't
That elaborate with their definition. There shouldn't be any splinters on this fretboard I trimmed it in Ebony. I think she'll be fine. Like I said she does have allergies. I hope she doesn't re-act to the wood as she's a beautiful little girl.
PostPosted: Sun Jul 13, 2014 9:13 am
Most people don't react to the wood per se, but rather the dust or oils. A cocobolo flute might give some people a fat lip, but that would be rare. A fingerboard shouldn't pose any problems.
PostPosted: Sun Jul 13, 2014 9:30 am
First name: Greg
Last Name: B
City: Los Angeles
Purpleheart works fine for necks and fingerboards. Think of it like purple rock maple. I used it for the neck and fingerboard of a tenor guitar harp thing I made a long time ago. It should be noted that it is a pain to work, being very hard and calcified, leading to the nickname: purple concrete.
IIRC Gibson used it for fingerboards a long time ago, but dyed it black.
PostPosted: Sun Jul 13, 2014 10:27 am
Last Name: Wilson
Country: Scotland
Purple rock maple or purple concrete eh.. I like that :-) It is very hard to work, but aslong as the tools are sharp it seems to cut and rout ok. It may reduce the life of tools quickly tho. I can see how someone working with it all the time could grow to hate it lol. I dont know if it was just me being a little paranoid but I had itchy hands while sanding it today. Hope the uke is ok lonnie but from what I have found elsewhere she should be fine. Only a splinter could cause a problem once its been finished apparently.
Again thanks for all the info here, you guys are awesome ;-)
These users thanked the author mechanix for the post: Lonnie J Barber (Sun Jul 13, 2014 10:33 am)
PostPosted: Sun Jul 13, 2014 10:55 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Purpleheart is really hard to carve or work... don't ask how I know (I am building a OM cutaway out of purpleheart).
Just use it as center lamination...
Typhoon Guitars
PostPosted: Sun Jul 13, 2014 4:07 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
ImageImagethis is that Uke with the Purple Heart.
PostPosted: Mon Jul 14, 2014 11:47 am
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
It's usually a brown color when freshly cut, but oxidizes pretty quickly to the purple color. It may also be a reaction to UV light, and not really oxidation. It's also really prone to tearout when routing.
PostPosted: Mon Jul 14, 2014 2:38 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
I didn't know that. But don't plan on routing any. It's heavy and hard I know that.
PostPosted: Tue Jul 15, 2014 12:29 am
First name: Jeff
Last Name: Dillard
it was used alot for truck beds
PostPosted: Tue Jul 15, 2014 7:14 am
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
Sounds like it was a catch all hardwood. Used for anything they needed, probably tons of it laying around. I made that fretboard but a nine year old girl picked it out. She had her choose Ebony,Rosewood,yellowheart. She chose the purpleheart because it was real close to pink I'm color. I have to admit it looks real purty. I hope it retains the purple color under the finish but don't think it will.
PostPosted: Tue Jul 15, 2014 1:33 pm
First name: Aaron
Last Name: Carter
City: La Follette
State: Tennessee
Zip/Postal Code: 37766
[quote="Lonnie J Barber"]Sounds like it was a catch all hardwood. Used for anything they needed, probably tons of it laying around. I made that fretboard but a nine year old girl picked it out. She had her choose Ebony,Rosewood,yellowheart. She chose the purpleheart because it was real close to pink I'm color. I have to admit it looks real purty. I hope it retains the purple color under the finish but don't think it will.
In my experience it is a reaction to UV light rather than oxidation in open air, it may be a little of both. The only way I have found to keep the color is to add a UV protectant to your finish.
PostPosted: Tue Jul 15, 2014 3:04 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
Well I don't know if Tru-Oil has such an addition. Probably not. If it turns she'll probably hate me.
