It is currently Wed Aug 06, 2025 11:55 am
 Post subject: thickness caliper
PostPosted: Wed Jun 04, 2014 8:08 pm
Last Name: Sollod
I was thinking about making a thickness caliper using a dial indicator. I found this one on Amazon.
http://www.amazon.com/TÜRLEN-DIAL-INDICATOR-SPEC-0-001/dp/B0043F779K/ref=cm_cr_pr_sims_t
It looks like it would work. What do you think? I'll have to put together a caliper. I'd like to see some shop made calipers so I can figure out how to make one. Can I see some photos?
www.swiftcreekguitars.com
 Post subject: Re: thickness caliper
PostPosted: Wed Jun 04, 2014 8:14 pm
Last Name: Sollod
Actually, this one doesn't measure thick enough because I want it for arch top tops. I'll have to choose another. But, I still want to see some calipers that others have put together...
PostPosted: Wed Jun 04, 2014 9:01 pm
First name: Rusty
Mine is two pieces of 3/4" plywood laminated together and a Mitutoyo dial indicator.
Due to wood movement it has to be zeroed every time I use it.
Sent from my iPhone using Tapatalk 2
PostPosted: Thu Jun 05, 2014 8:57 am
I was going to make one but realized I could get an extremely nice one used for very little. Mine is just like this one:
http://www.ebay.com/itm/AMES-HANDLED-DI ... 4ad6545a88
I love it, it works perfectly.
Burton
Brookline, MA.
PostPosted: Fri Jun 06, 2014 3:57 am
I made this from plywood, works well enough. I don't know if would've borthered if I'd known I could get one for as little as the one Burton showed, though...
PostPosted: Fri Jun 06, 2014 5:32 am
Made mine before I got allergic to Coco. Used the parts from my old broken violin dial caliper that I had for 25 years...
PostPosted: Fri Jun 06, 2014 6:19 am
Nice fix Haans!
These users thanked the author Colin North for the post: Haans (Sat Jun 07, 2014 7:59 am)
PostPosted: Fri Jun 06, 2014 7:48 am
First name: Dan
Last Name: Pennington
City: Brooklyn Park
State: MN
Zip/Postal Code: 55428
Here's my version of a thickness caliper. Not as pretty as some but it works for me.
PostPosted: Sat Jun 07, 2014 9:34 am
First name: Patrick
Last Name: Hanna
State: Missouri
Steve, this isn't what you have in mind, but it works for me. When I contemplated mine, I was not concerned so much with measuring thickness as with visualizing thickness. My reasoning was that I would do further scraping and sanding after the box was closed, so I just wanted to get in neighborhood, so to speak. I tried to make the tool pretty, and have never seen the need to supplement it with a dial caliper. But that's me. You might want to be more precise. Here ya' go:
PostPosted: Sat Jun 07, 2014 11:01 am
First name: David
Last Name: Eddy
City: Mandeville
State: La
Zip/Postal Code: 70448
I just used what I had in the shop!
PostPosted: Sat Jun 07, 2014 2:56 pm
Last Name: G
I was going to make one from plans I found online here:
http://sd-1.archive-host.com/membres/up ... ISSEUR.pdf
When I went to eBay to buy a dial indicator I found a Kafer K200 graduating caliper for the price of a chinese dial indicator...
Users browsing this forum: meddlingfool and 46 guests
