It is currently Sat May 16, 2026 12:35 am
 Post subject: New to me Joiner!!!
PostPosted: Tue Apr 15, 2014 6:33 pm
First name: Brad
City: St. Louis
I bought this on the Bay last night, and it turns out the guy lived down the street for me. It is in excellent condition for being 75 years old, and should make joining tops and backs a dream from now on!!!
Brad
 Post subject: Re: New to me Joiner!!!
PostPosted: Tue Apr 15, 2014 6:56 pm
Sweet!
PostPosted: Tue Apr 15, 2014 7:18 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Let the shavings begin!
Alex
PostPosted: Tue Apr 15, 2014 7:23 pm
Last Name: Curtis
City: Mangrove Mountain
State: N.S.W
Zip/Postal Code: 2250
Bet i won't look that good if i make 3/4 of a ton.
PostPosted: Tue Apr 15, 2014 7:26 pm
Last Name: Kincheloe
Is that a Brazilian rosewood handle? Must sound beautiful when making shavings laughing6-hehe
Nice score. Looks perfect for plate jointing [:Y:]
PostPosted: Tue Apr 15, 2014 8:01 pm
First name: Brad
City: St. Louis
It looks like Brazilian to me...
Brad
PostPosted: Tue Apr 15, 2014 9:19 pm
Nice. I dusted of my 10$ garage sale #7, and it's been helpful for plate jointing for sure.
PostPosted: Wed Apr 16, 2014 2:06 am
Last Name: Russell
State: Michigan USA
You won't regret that purchase. I just used mine a couple of days ago to true up the edge of my fretboard for the bindings.
You will probably find uses for it that you never thought you needed before. I am not sure how you join plates but it works really well as a weight to keep the parts flat when you glue them together.
I am sure you will enjoy it.
Cheers,
Bob
PostPosted: Wed Apr 16, 2014 7:17 am
Congrats! It's in fine shape.
Looks just like mine except for the Stanley stamp on the lever cap. My iron is stamped with "Stanley Rule and Level". Those totes on the old ones are Brazilian.
PostPosted: Wed Apr 16, 2014 8:29 am
I'd like to hear about that Haans. The sole on mine is flat, but the shooting side is not 100% square.
PostPosted: Wed Apr 16, 2014 8:47 am
Mine isn't either, but not sure that is important.
If you book your halves, the joint works. If it is important for you to have a 90 degree joint instead of an 89 degree or so, have it milled flat and square on one side.
PostPosted: Wed Apr 16, 2014 8:50 am
What a beauty! True that up and you are good to go.
PostPosted: Wed Apr 16, 2014 9:13 am
First name: Big
Last Name: Jim
Nice Find !
PostPosted: Wed Apr 16, 2014 10:27 am
Square edge to the blade. Might even be the original. Get the blade super sharp, make sure the chipbreaker fits well and off you go. I wouldn't bother fitting an after market blade either, providing that one is fine.
PostPosted: Wed Apr 16, 2014 12:40 pm
Last Name: Lewis
City: Newnan
State: Georgia
Zip/Postal Code: 30265
+1 on comments above.
That is a nice looking plane.
I spent $85-90 on Hock iron/chipbreaker combo for a Stanley 4 1/2. It works great but then I sharpened the original iron and got the original chipbreaker fettled. I put the original iron/chipbreaker back in and it works the same. Just make sure to get the chipbreaker setup correctly (tip honed at 70-75 degrees and set VERY close to the iron's edge).
I hope you asked the eBay seller if he has any more tools for sale. Sounds like a good guy to get to know.
John Lewis
PostPosted: Wed Apr 16, 2014 1:34 pm
I think I have a at least a few dozen blades - some old, some new, some expensive, some cheap. Virtually all of them are good enough to use in a professional capacity on a day to day basis. I have a few that seem to stand out just a touch from the rest - an old Stanley Rule and level from a 102 block plane, an old Sheffield blade in a woody and an old Acorn blade. I've also been impressed with the blades in those little wooden Chinese Planes. The rest are fine, including the original thin blade in my '70's Stanley 5 1/2. The plane actually works very good, despite it being from an era when Stanley Planes were rapidly going down in quality.
PostPosted: Wed Apr 16, 2014 1:36 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
To paraphrase Mick Dundee, that ain't a joiner, this is a joiner
But seriously, that is sweet looking. As a plane collector that is in as good a shape as I have seen.
Brian
PostPosted: Wed Apr 16, 2014 1:39 pm
Last Name: Russell
State: Michigan USA
My plains are Baily but essentially the same thing. I think the difference is the Baily has adjustment screws for the frog.
Even though it is is really good shape I would do a couple of things when you tune it up. I would lap the top of the frog to be sure it was dead flat as well asthe back of the iron. Those need to mate perfectly or you could get chatter or it could be harder to adjust while you are using it. The other thing is to file the mouth to the exact same angle as the frog and make sure it is square to the plane. Those few things will make it rock solid when plaining and you will not get any chatter. The Cap iron also needs to mate up with the iron perfectly or you will get shavings jambing up between them. Put the Cap Iron and the Iron together but don't bolt them tight. Hold it up to a light so you can see where they touch. There shouldn't be any gaps between the two.
As for the iron, you will probably be just fine if it is a Stanly. I bought a Stanly SW blade for mine but I also have a bunch of standard Stanly irons and the only difference is my SW iron stays sharp longer. It may get a bit sharper then the standard ones but for price vs performance the standard ones are just fine.
Cheers,
Bob
PostPosted: Wed Apr 16, 2014 3:14 pm
First name: Tom
Last Name: West
State: Nova Scotia
Meddling:
The side does not have to be 90 degrees to the sole. Just shoot one side show face up and the other side inside face up and any mismatch from 90 degrees cancels out.
Tom
PostPosted: Wed Apr 16, 2014 4:17 pm
Thanks...
PostPosted: Wed Apr 16, 2014 4:41 pm
I believe that is what I said. Shoot them both together, booked.
PostPosted: Wed Apr 16, 2014 6:31 pm
First name: Brad
City: St. Louis
This one came with a blade that's basically unused and in great condition. I'll stick with the original steel on this one.
Brad
Users browsing this forum: No registered users and 51 guests
