It is currently Sun Jul 27, 2025 5:59 pm
 Post subject: case building
PostPosted: Mon Jan 13, 2014 4:01 pm
First name: Mark
Last Name: Gilman
City: 150 Mile House
State: British Columbia
Zip/Postal Code: V0K2G0
I am going to build a hardshell case for my custom archtop and have been searching liner materials. Considering sheepskin. Any input on case building or where to get liner materials? Stew-mac has handles, hinges, and covering .Thanks
 Post subject: Re: case building
PostPosted: Mon Jan 13, 2014 5:35 pm
Last Name: Russell
State: Michigan USA
I would go to a fabric store. Most of the lining in a case is man made "fake fur" of some sort. You will need fake fur and some foam padding both of which could be found at a decent fabric store.
PostPosted: Mon Jan 13, 2014 5:57 pm
Crushed velvet. Also look for fabric adhesive.
PostPosted: Mon Jan 13, 2014 8:10 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
I used foam pads, a large towel, and "Foam-safe" spray adhesive from Walmart
for custom fitting a case to a parlor I built for my granddaughter.
Gene
PostPosted: Tue Jan 14, 2014 10:49 am
at the autry museum there's this nice little martin parlor coffin case. made from pine and painted green, i'm going to replicate one of these some day. i was thinking about using some velvet and some sort of foam or terry cotten material for padding under it. maybe the foam will outgass -not sure, but i think one needs to consider vapors coming from adhesives, etc... otherwise you'l have something like taylor's "chemical warfare" case smell.
PostPosted: Tue Jan 14, 2014 9:58 pm
I've build a couple of coffin cases. They are fun and easy to build. I used 1/2 inch pine for the sides and 1/8 inch plywood for the top and bottom. I used a "velvet" material to line the case and wrapped the material around corrugated cardboard to provide some padding and make it easier to install. The blocking I made from stacked and glued up layers of cardboard which I then cut to shape on the bandsaw.
These users thanked the author Clay S. for the post: arie (Wed Jan 15, 2014 10:56 am)
PostPosted: Wed Jan 15, 2014 10:56 am
cardboard....interesting. will have to check that out. thx
