It is currently Thu May 14, 2026 9:25 pm
PostPosted: Mon Jan 06, 2014 2:11 pm
First name: Rusty
I don' have a proper humidifier so I hung a wet towel from the garage door track (btw, I disabled the opener) and put a damp sponge/travel soap dish in body.
Hygrometer staying around 35%.
Sent from my iPhone using Tapatalk 2
These users thanked the author RustySP for the post: bobgramann (Mon Jan 06, 2014 6:43 pm)
PostPosted: Mon Jan 06, 2014 2:33 pm
I have four separate humidifiers going in my shop in the different sections. A big double canister Honeywell under the wood shelf, a wee little one in the side bending room, a self regulating one in the paint room, and a self regulating one in the glue up room.
PostPosted: Mon Jan 06, 2014 2:39 pm
I'm in Florida, it finally dipped down to 57 degrees. I'm still dehumidifying.
Old growth, shmold growth!
These users thanked the author theguitarwhisperer for the post: EddieLee (Tue Jan 07, 2014 10:08 am)
PostPosted: Mon Jan 06, 2014 3:32 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
I need larger humidifier. Right now I run 2 small ones that I fill 3 times a day. Right now I'm sitting at 36% because its a toasty 20 degrees outside. When the temp dips my heater runs full time and it really dries the air out. When that happens it sits around 25%. Maybe I'll give the wet towel a try. When I get my taxes back I'm planning to buy a larger 9 gallon unit and move one of the smaller ones to an insulated room upstairs where the guitar will live.
PostPosted: Mon Jan 06, 2014 3:47 pm
Last Name: Sayers
City: rayne
State: essex
Zip/Postal Code: CM77 6TQ
Country: England
Is that a Stew Mac rosewood on the form? Any way, I don't really worry about humidity here in Essex England. In winter I take tonewoods into the workshop if the temperature is above 9 degrees, and they come in at night. Otherwise I make things that aren't temperature critical except for the gluing. Side bending jigs I shall be attempting for a J45 and J200, maybe a little routing guide for the neck on the laminated 12 string I'm working on. Laminates are good for trying things out in low temperatures.
PostPosted: Mon Jan 06, 2014 3:49 pm
Last Name: Russell
State: Michigan USA
Here in Michigan it is C...O...L...D...
Outdoor temp is 2.7 degrees (F) and humidity is 72%
Indoor is 73 degrees and humidity is 46%
My shop is located in 3 separate areas in my house. My office which has a small bench for doing fretwork and small jobs, Downstairs in a 12X17 room and my downstairs garage which is attached but not heated yet . The temp usually runs about 40 degrees in the big shop because it is earth bermed on 2 sides and attached to the house on one and is walk out on the other (and no windows). That is pretty much used for my big saws and spraying finishes so I am not out there much in the winter except to cut wood.
I run a furnace attached humidifier and a whole house humidifier which keeps everything consistant at between 40% and 48%
I normally only have to fill my whole house humidifier about once a week or so but since we are in a deep freeze I have had to fill it every day. That is 14 gallons of water just in that humidifier and I have no idea how much my furnace humidifier uses since it is piped into the system and is automatic. I have been amazed how much water I am pumping into the air to maintain 45%
Winter SUCKS!!!!
PostPosted: Mon Jan 06, 2014 3:55 pm
Last Name: Russell
State: Michigan USA
@RustySP,
I forgot to add this:
Why don't you try getting a hot plate and put a big soup pot full of water. That is what I used to do before I got a big enough humidifier. It really works well and you don't really have to have it boiling, just hot enough to put steam out. If you are running any kind of heater that you can put the pot on it will work really well. I use to have a small oil space heater for my old shop and a big pot of hot water comes in handy for more than just humidity.
PostPosted: Mon Jan 06, 2014 5:42 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Winter SUCKS!!!!
2 degree? That's sweater weather!!! Lol. It was 22 yesterday here and I was rocking shorts and a tee shirt. Of course it was 60 degrees cooler last week so 22 feels pretty nice. It's a dry cool laughing6-hehe I love winter though and Alaska is so gorgeous in the winter. Summer is annoying up here. The sun doesn't go down- thick smoke from forest fires and there's no A/C anywhere.
PostPosted: Mon Jan 06, 2014 6:12 pm
First name: Big
Last Name: Jim
Its a Balmy +1 here today and the Humidifier is screaming wide open to keep me at 37% ... Worst ive ever seen it in this shop ...
PostPosted: Mon Jan 06, 2014 6:47 pm
First name: Rusty
Dave that's LMI rosewood.
RusRob, I thought about using a pot of water on a hotplate just today while I was watching the towel drip water on the floor, thanks.
PostPosted: Mon Jan 06, 2014 6:49 pm
I doubt that a wet towel will have much of an effect, unless you have a highly sealed workshop. As stated previously you would be better served by using steam, a lot faster and a lot more effective.
PostPosted: Mon Jan 06, 2014 7:55 pm
On the driest days, I'll throw a few pots of water on the unsealed concrete shop floor. Instant humidity, and it lasts a full day, releasing moisture gradually as it evaporates out of the floor.
Ken Jones
Mountain Song Guitars
Mountain Song Guitars www.mountainsongguitars.com
PostPosted: Mon Jan 06, 2014 8:23 pm
That's funny, Joey has 22 in Alaska and we woke to -16 in Chicago.
I do somewhat like Ken but it's a few shovels of snow when I leave the shop at night.
PostPosted: Mon Jan 06, 2014 8:35 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
This puppy dumps up to 18 gallons into the forced airstream daily.
PostPosted: Mon Jan 06, 2014 9:21 pm
It's -10 deg.F right now in central Ohio. Humidity in my shop is down to 21. I gave up and closed the shop for the next couple of days. [uncle] Clinton
PostPosted: Mon Jan 06, 2014 9:37 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Hahaha, I think that's just our -48 from last week up here making it's way South/East. It's been great weather this week. Actually able to hold some humidity in the shop.
PostPosted: Mon Jan 06, 2014 9:49 pm
Online
Last Name: Kincheloe
That's a lot of water :shock: What becomes of all of it? Whenever I've tried to humidify in the winter, it just condenses on the windows and then runs down and rots the wood or curtains.
It's been really dry here for the past few weeks, but there must have been some trace of moisture left in the air because it was all frozen on the windows when I woke up :lol:
PostPosted: Mon Jan 06, 2014 9:58 pm
First name: duh
Last Name: Padma
Cold temps???
go here dudes....
http://www.luthiersforum.com/forum/viewtopic.php?f=10112&t=42410
PostPosted: Mon Jan 06, 2014 10:07 pm
First name: Rusty
That's funny Padma, but it's cold for Louisiana.
Michael, you are right about the towel, not very effective.
Ken, my Beagle will be putting down some water on the floor tomorrow while I'm at work.
PostPosted: Mon Jan 06, 2014 10:20 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
My runny nose is actually keeping the entire house at a comfortable RH. [uncle]
Alex
PostPosted: Tue Jan 07, 2014 2:14 am
First name: nick
Last Name: dingle
While I don't really miss the kind of cold weather NY/NJ is having at the moment, I'd almost trade it for my current climate. Friday last. 96degrees and 90%RH. Saturday 108degrees and 90%RH.
Just a leettle beet uncomfy.....Oh, as it's usually pretty good around here, we haven't any air conditioning.......
PostPosted: Tue Jan 07, 2014 9:51 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
Relative Humidity is .. well .. relative, and it's relative to temperature. If I heat up air, its RH drops and if I cool down air, its RH rises. Dew point is nothing but air that has cooled enough to reach 100% RH, them some more and the moisture condenses on any cold surface it sees.
I am in energy conservation and indoor air quality contracting. There is only one problem I can diagnose over the phone. If someone tells me that he gets sparks when he touches the light switch in the carpeted living room, I know that is a dry house and I say "hey, you're house is very leaky".
For you guys in the garage (and for your house too), air leakage will dry the space. Warm, humid inside air leaks out and cold outside air leaks in. As the cold air heats, it's RH drop dramatically. If the space were 100% airtight and you kept it at a constant temperature (insulation levels don't matter for this), the RH would not change regardless of the outside temperature. So find the big leaks and seal them - around the garage door, any hatches into the attic above, where the wall meets the foundation, holes where the garage door rails go through the ceiling, etc. It will be easier to humidify (and heat too).
Stay warm
Ed Minch
PostPosted: Tue Jan 07, 2014 10:23 am
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
It was 0 degrees outside when I got up this morning. Shop temp is at 55 degrees. Humidifier in the shop was reading 32%, but the hygrometers were reading 40-50%. I usually leave the humidifier on level 1 in the winter but when it gets this cold I crank it up to 3 (high as it goes). My basement shop is pretty well air tight (see Ed's great advice above).
PostPosted: Tue Jan 07, 2014 10:48 am
Last Name: Russell
State: Michigan USA
It is still bitter cold here in Michigan but I saw something very strange today. I am not sure what I was seeing but the sky had some strange blue patches and this really bright object could be seen. I am not sure what it was but it was almost blinding and it lit the ground up and was coming through the windows almost blinding me.
I have heard of strange lands where the sky turns a beautiful shade of blue and this thing is visible for hours at a time .
PostPosted: Tue Jan 07, 2014 11:14 am
I wanted to thank Ed for his excellent explanation of RH in a home and shop! [:Y:]
I'm not holding up well and have yet another day where I can't leave because the road has not been plowed and now the snow is pretty much hard and icy too.... It was -15F last night which makes me nervous and unable to relax.... I called the road commission this morning and spoke to the supervisor and requested that he pull his finger out and come do my roads. He hung up on me. Go figure.... :D
Still running four humidifiers, a huge pot of water on the range, the shower every hour or so, and we are approaching 40% but still not yet there....
Although I know better most of my personal instruments including mandos, guitars, etc. are hung on walls (inside walls only) and not in cases.... So I have to maintain decent RH throughout my home which can be difficult in this crappy weather.
But they are calling for it to go UP to zero.... today which would be very welcome under the circumstances.
On the plus side and not that I would wish this on anyone this time of year our bread and butter is crack repair. And no we are not proctologists either.... ;) So this weather should bring lots of business our way for both repairs and case and guitar humidifiers.
Hope everyone is safe and warm too!
Users browsing this forum: Bing [Bot], DennisK, doncaparker and 176 guests
