It is currently Tue Jul 29, 2025 9:45 am
PostPosted: Fri Jul 19, 2013 8:06 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Luckily an old customer brought his Gibson SJ-300 for repairs, and I took the opportunity to copy the body shape and the bracing. The body shape was copied by placing it on a piece of paper and tracing them with a half pencil (you know what that is...), and from that a plywood template is made. I got the bracing by putting a very bright light bulb (CCFL lights so I don't overheat the guitar) inside the body, turning off the light in the room, and just traced the pattern. The tone bars have to be reversed though otherwise it won't be right (because you are look down at the body, but bracing pattern for most plans are looking at the flip side of the soundboard).
By the way I asked the owner if I could do this and he's fine with that. Just don't put a Gibson headstock on it...
Typhoon Guitars
PostPosted: Fri Jul 19, 2013 9:37 am
Nice.
I usually use magnets to trace the bracing. One inside, one outside. Just butt it against the brace inside, and the one outside will follow it.
PostPosted: Sun Jul 21, 2013 5:00 pm
Last Name: Beaver
City: Lake Forest
Nice job. I use the light in the box also. Works well
Joe Beaver
Maker of Sawdust
