It is currently Fri Aug 15, 2025 10:46 am
 Post subject: Wiring diagram
PostPosted: Sat Jul 20, 2013 10:23 am
First name: herry
Last Name: trismono
City: malang
State: east java
Zip/Postal Code: 65142
Country: Indonesia
Hi,.. do you have wiring diagram for I need? duh
I need to change my wiring: Neck pickup Seymour Duncan SH1N and Bridge pickup Seymour Duncan SH14
with 2 vol and 2 tone with 3 switch lever and this wiring I used from SD: 2 Humbucker, 2 volume, 2 Tones, 3 Way Switch
front switch work for neck, back switch work for bridge. But now I need for the Middle Switch () works for both of them (neck and bridge), what should I do... [uncle]
I need your suggestion,.. thank's herry.
 Post subject: Re: Wiring diagram
PostPosted: Sat Jul 20, 2013 12:18 pm
Hi Henry .. depends on the swithc type .. blade style, like a tele, toggel, like a les paul ... if its the les paul style, then there are 4 tabs .. the outer ones are the inputs, the inner ones the outputs . you need to solder the output tabs together. If its a tele style, then there should be two sides, each with its own tabs and slider inside the switch. Each PU has its own side, and again, you need to tie the outputs together. You also need to have each PU on its own side touch two of the tabs, ie. on one side the PU is soldered to tabs in position1 and 2, the other side has the PU soldered to tabs in position 2 and 3 ....
Look at the wiring diagrams at Duncans site .,.. they are pretty good.
