It is currently Fri Aug 22, 2025 7:28 pm
PostPosted: Sat Jul 06, 2013 4:18 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I notice body modes use a LOT of plywood... and leaves a lot of waste too. So I was wondering why should I use baltic birch for making molds instead of MDF or regular 7 ply construction plywood?
I just picked up some baltic birch plywood... man it's so expensive. Paid about 60 dollars for one sheet 150cm x 76cm, 18mm thickness. I rather not use it if it's not absolutely critical...
Typhoon Guitars
PostPosted: Sat Jul 06, 2013 6:27 am
I've just made a couple from 18 mm Baltic Birch. My first ever moulds even though I've been making for over 30 years!
They are an outside mould, just one layer and only 30 mm wide around the perimeter. Pretty minimalist as moulds go. Very light in weight too. I don't really see the point in using 4 or 5 layers when you can just use one layer or 2 or 3 layers with spacers. Save a lot of material that way.
PostPosted: Sat Jul 06, 2013 7:13 am
Regular construction ply here, 3 x 18mm, 50 mm wide sides for outside molds
Birch Ply is way too expensive
PostPosted: Sat Jul 06, 2013 7:18 am
First name: Jim
Last Name: Kirby
I use big box plywood but with a smooth face - not construction stuff for subfloors, etc. I agree Baltic is too expensive for this application.
Jim Kirby
kirby@udel.edu
PostPosted: Sat Jul 06, 2013 7:28 am
First name: Jim
Last Name: Kirby
Todd - where do you go for BB? Sources I know of in the Wilmington DE area are way too expensive.
I wish I had bought a bunch of the birch ply from Chile that Home Depot had a couple of years ago. It was nice stuff and cheap too. Maybe they will have it again but I haven't seen any recently.
Jim Kirby
kirby@udel.edu
PostPosted: Sat Jul 06, 2013 7:34 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
3/4" construction grade, lighter but ugly, in my mind I am building a tool not furniture.
Fred
Fred Tellier
PostPosted: Sat Jul 06, 2013 8:00 am
the thing about BB is this: it's outer layer is not a veneer, it's a far more substantial layer of wood which won't easily delaminate...I'd prefer to use BB for the outer layers and cheaper stuff for the interior...
PostPosted: Sat Jul 06, 2013 8:17 am
If you are not making a block mold at the same time as you are making an outside form (in which case you are not wasting a whole lot of plywood) you can make the outside form from smaller pieces. I have used scraps of 3/4 inch plywood and staggered the joints to make 3 layer, 2 1/4 inch thick outside forms. Use plenty of glue to stick things together and they are stiff enough.
PostPosted: Sat Jul 06, 2013 9:20 am
I just use MDF!
PostPosted: Sat Jul 06, 2013 11:17 am
First name: duh
Last Name: Padma
Blocked and lamed dimensional lumber, OSB, MDF, sub flooring, G1S, Baltic...it all depends on your persuasion and your bank account. All will work.
Gee you could even use glued up cardboard boxes for that matter.
PostPosted: Sat Jul 06, 2013 1:39 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Baltic birch is not only expensive in Taiwan but hard to find.... they only sell one type of plywood and it's the crappy type, and a 3x6 sheet still costs about 30 dollars (for the crappy plywood that is)
Typhoon Guitars
PostPosted: Sat Jul 06, 2013 2:21 pm
MDF or 1/2" construction grade spruce ply("sheathing") here.... MDF works fine, but is heavier than the spruce ply and as I age, I seek to build lighter molds....
PostPosted: Sat Jul 06, 2013 2:26 pm
State: Tennessee
Yes
PostPosted: Sat Jul 06, 2013 2:52 pm
French Skeleton version. Should save a few coins. I'll chop the bolts later. I've yet to try it but see no reason why it won't work.
PostPosted: Sat Jul 06, 2013 4:42 pm
Last Name: Eaton
City: Lamoine
State: ME
Zip/Postal Code: 04605
I would def save your baltic birch plywood for some other more critical application. It makes wonderful jigs that require a nice stable substrate. And good quality baltic is really a furniture grade plywood that is free of any voids and has a great looking surface veneer (although thick is still considered a veneer). There is nothing wrong with using MDF as a mold, its downfall would be its weight and the fact that it really doesn't like to get wet at all. But the wet issue is easily fixed by applying a finish. I personally would rather use MDF as I think a heavy mold would actually be benificial other than having to lug it around. My other problem with MDF is the dust produced while machining.
PostPosted: Sat Jul 06, 2013 5:03 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
+1 grumpy. I have made molds from all types of wood BB , chinese birch ply from homeless depot and MDF , cheapo fir plywood, 2 layers of mdf with cedar spacers from the kinkade book etc etc.
PostPosted: Sun Jul 07, 2013 5:50 pm
That'll work to hold the shape, but it won't help prevent "racking"(IE: twisting) of the rim when gluing the top and/or back to the rim, which is one of the most important tasks of a solid mold.
Just make a second pair, and use spacers between the two. It's all I do, now. At thew waist, I'll build-up a solid stack of spacers and using a router bit and top bearing, trim the block flush to the form. This gives me a solid waist area to prevent cracking the ribs when using a spreader.
PostPosted: Mon Jul 08, 2013 12:46 am
I won't need to do that Grumpy. The Back Bars are first glued into the Sides with the actual Back plate glued after. That's the Torres method apparently. I've never tried that before but many have. Anyway, no chance of the twist you refer to.
