It is currently Sat Jul 26, 2025 10:07 am
PostPosted: Sat Jun 22, 2013 3:22 pm
Those who make their own forms, what do you use to hold the two "outlines" together.
I see for example that Bruescreek Guitars use metal tubing, and I believe I have heard of people using aluminum "strip", (maybe about 3/4" x 1/8" on "edge")
Just wondered what you guys use, and do you secure them in some way, e.g. are epoxy/superglue fit for temperatures involved, or do you use screws/pins, etc?
PostPosted: Sat Jun 22, 2013 4:02 pm
State: Tennessee
I have a Blues creek bender, it came with one bending pattern D size, with the 1/2 conduit to hold it together, I misplaced the conduit and substituted 1/2" poplar dowels. I've built O, OO, OOO/OM & Gibson L-OO/Nick Lucas bending patterns using the dowels works great.
PostPosted: Sat Jun 22, 2013 4:20 pm
First name: Tim
Last Name: Allen
City: San Francisco
On my first one I used 3/4" hardware store dowels, made of some kind of some type of inexpensive Asian wood. They are glued with Titebond but I imagine a friction fit would work. For my second form, I didn't use spacers--I followed Todd Stock's tutorial on this forum, which suggests using thee layers of 3/4" plywood. Having tried it, I am partial to that method and would recommend you consider it if you haven't yet. Of course, both types seem to work pretty well.
Tim Allen
"Never hurry, never rest."
PostPosted: Sat Jun 22, 2013 4:59 pm
I use 6 pieces of 3/4 inch plywood and make a solid block form. Sometimes I cover it with HPL if I am also going to use it for molded sides. I use kerf core as a "clamping blanket" over the heat blanket or as an outside form for molded sides. I use titebond to glue up the block form. The forms are a bit heavy but "solid" and easy to make.
PostPosted: Sat Jun 22, 2013 5:40 pm
Last Name: Beaver
City: Lake Forest
I too use a solid form. I use Baltic ply on the outside and MDF pieces for the center. I make it with a cavity in the center so the center pieces are lighter. Then I cover it with a stainless steel slat
Joe Beaver
Maker of Sawdust
PostPosted: Sat Jun 22, 2013 7:52 pm
First name: Tom
Last Name: West
State: Nova Scotia
Solid form........!
Tom
PostPosted: Sat Jun 22, 2013 8:13 pm
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
Zip/Postal Code: 33634
I initially started with the two outer forms with steel rods between per the plans I used. However, I have since switched to 3 forms with plywood spacers connecting the three pieces. I think you get better support across the width of the sides as you bend. A solid form would be even better. This assumes you're bending with a blanket and not using light bulbs.
PostPosted: Sat Jun 22, 2013 11:37 pm
For this one I want to try both heating blanket and light bulbs.
PostPosted: Sun Jun 23, 2013 7:16 am
First name: Trevor
Last Name: Gore
City: Sydney
Double width Fox bender, heating with globes, 12 off, 1/2" steel bars, 300mm long, push fit. One set of bars for many different forms so that the forms store flat. It takes about a minute to assemble a form by threading the bars in.
http://www.goreguitars.com.au
PostPosted: Sun Jun 23, 2013 7:32 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I have always used two forms with 1/2" wood dowels instead of steel but on my last form I did it with 3 forms and only a few dowels to hold it together. This will not work with bulbs but I think the advent of the heating blanket being available make the bulbs obsolete. I always thought that bulbs were a dangerous and unreliable way to create heat.
Here is a shot of my Bouzouki form and outside mold.
Fred Tellier
PostPosted: Sun Jun 23, 2013 7:44 am
First name: Ringo
This. No need to glue in the bars unless you have way too much storage space.
PostPosted: Mon Jun 24, 2013 1:25 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
I do pretty much the same, 1/2" plywood with 20 1/2" steel bars, use the same 20 bars for jumbo, dred, L-00, and parlor. I still use light bulbs for heat. I'd go to a solid form if I used a blanket.
PostPosted: Mon Jun 24, 2013 6:55 pm
One thing I forgot to mention, and another reason I use a solid form, is that I make the block form and the outside mold at the same time. I cut just inside the outline on 6 pieces of 3/4 inch plywood, and then between routing and sanding to true up the patterns I have an outside mold and a block form of about the right dimensions.
PostPosted: Mon Jun 24, 2013 10:16 pm
City: winnipeg
State: manitoba
Country: canada
I use a light bulb base with two 150 watt bulbs and build all my molds to fit on or around that base.
I build the side forms from 3/4" particle board lined with aluminum foil (spray adhesive). The forms are separated using 3/4"square wood spacers drilled finishing nails (aluminum foil preferred) two inches between them. Flashing aluminum covers the mold.
It has worked for me so far.
Bob :ugeek:
