It is currently Tue Aug 12, 2025 12:32 am
 Post subject: Neck block question.
PostPosted: Mon May 13, 2013 7:59 pm
First name: Rob
Last Name: Forsythe
City: Ottawa
Zip/Postal Code: K1C 2A7
I am currently working on my first build. What are the dimensions of the neck block, I know the length is the depth of the body but what are the other typical measurements.
Rob
 Post subject: Re: Neck block question.
PostPosted: Mon May 13, 2013 8:24 pm
State: ON
My blocks are the height of the sides X 2 1/2" wide X 1 1/8" deep. I use an "L" shaped block that extends under the fretboard. I know there are a number of other builders who make their blocks wider and deeper than I do. I'm sure you'll get some other responses.
Josh
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Mon May 13, 2013 9:07 pm
2 3/4" x 1 3/8"...
PostPosted: Mon May 13, 2013 9:59 pm
City: winnipeg
State: manitoba
Country: canada
2 3/4 X 5/8 on ukuleles
Bob :ugeek:
PostPosted: Tue May 14, 2013 1:58 am
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
Zip/Postal Code: 54601
Need more info. What are you building?
Jason Moe
LaCrosse WI 54601
PostPosted: Tue May 14, 2013 5:38 am
First name: Rob
Last Name: Forsythe
City: Ottawa
I'm building a curly maple/Appalachian top Nick Lucas. The neck will also be Maple, 14 fret clear of body.
PostPosted: Tue May 14, 2013 9:25 am
Most of the blueprints I have have neck blocks that average out to 2 3/4" x 1 3/8". That block size worked in the OO nl I'm working on right now. Just be sure your truss rod is long enough to clear the block, or at least that your wrench is long enough to adjust it....
PostPosted: Tue May 14, 2013 10:36 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
That is a consideration on any build and especially relevant on a 12 fret, I had to make a custom wrench for one and now I check before I get too far with the neck construction. Like the old saying measure twice and cut once.
As for the depth of the block make sure it is thick enough to cut the dovetail of mortice and leave enough wood for strength. For cutaway guitars the my block is narrower than a non cutaway, I mark the center and then trim the cutaway side to match the side shape.
Fred
Fred Tellier
PostPosted: Tue May 14, 2013 10:53 am
i usually go wider and sometimes use a foot as well -really depends upon the guitar though. whatever the design make sure you have room for fasteners (if you are going bolt on that is), c'bores, washers, as well as wrench access should be figured out in advance otherwise you'll have to resort to "custom" hardware. i've run into problems before in this area specifically with belleville washers. they need a bit of room on the diameter to allow them to flatten out a bit. i had to do some research to find some in stainless steel that were .030 smaller then what came with the hardware kit.
PostPosted: Tue May 14, 2013 11:11 am
First name: George
City: Seattle
Fred Tellier wrote:
That last part is where I could use some help. What's a safe amount of wood to have left once you've cut the mortice?
George :-)
PostPosted: Tue May 14, 2013 11:24 am
really depends upon the guitar imo. i strictly use bolt on m/t. if my tenon is 1" x 1" then i like to have 3/4" all around, if my tenon is 3/4" x 3/4" then i like to have 5/8" all around. hardware is a driver as well though and you need to consider whether you are going to c'bore the bolt heads or not and determine c'bore depth (or not depending). i also like to keep a fairly wide face where the neck heel meets the body and i also radius the upper bout here as well and this will impact overall block width. i like to work in thirds as this just seems natural to me but i'm pretty much a underground fringe builder though so don't necessarily do as i do, as experience and forum opinion will vary greatly. :)
PostPosted: Wed May 15, 2013 12:55 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
I make it about 1/2" wider than the neck at the body joint. The glue surface will help flatten any warping or cupping in the sides. Makes sanding that area for the neck joint easier.
Users browsing this forum: No registered users and 61 guests
