It is currently Wed Jul 30, 2025 8:52 pm
 Post subject: Nitro over Pearloid?
PostPosted: Sat May 04, 2013 8:11 am
First name: Gerry
Last Name: Gruber
City: Ottawa
Zip/Postal Code: K1C 3H4
I'm planning a build for export to the USA, and am hoping to avoid the USFWS "tax" by not putting any shell on it. I'm considering pearloid for fret markers and headstock inlay. However, for the headstock inlay, there could be a problem. I use nitro for my finish, and I suspect that the nitro might melt the pearloid. Has anyone had experience shooting nitro over pearloid? Can it be done? Any tricks to successfully doing so?
 Post subject: Re: Nitro over Pearloid?
PostPosted: Sun May 05, 2013 5:40 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Celluloid of all types, not just pearloid, was used almost exclusively for instrument bindings from the 20's into the 70's under lacquer finishes without any problems.
Brian
PostPosted: Fri May 10, 2013 11:54 am
First name: Gerry
Last Name: Gruber
City: Ottawa
Hi Brian and Todd. Thanks for the input. I never thought of all those older guitars with celluloid bindings under lacquer. Good point. And the adhesion advantage.... I'll take that. Mind you, I've never had adhesion problems with shell. Don't ask me about ebony or EIR. Thanks again.
PostPosted: Sun May 12, 2013 4:23 am
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
The pearloid available today may or may not be celluloid. It could be polyester, or some oither modern plastic. At any rate, lacquer is compatible with most kinds of plastic.
Not only celluloid bindings, but many older instruments had celluloid on the peghead....either as ivoroid or pearloid.
