It is currently Sun Aug 17, 2025 8:05 pm
PostPosted: Thu Feb 14, 2013 12:13 pm
First name: Blake
Last Name: Dixon
City: Kelowna
Zip/Postal Code: V1V1W7
I am about to make an order for Cardnial finish instrument coating. Should I only use their sealer or is everyone sealing with a spray shellac and nothing else?
Blake.
Blake Dixon
Kelowna B.C.
PostPosted: Thu Feb 14, 2013 1:07 pm
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
I have only done one. Sealed the top with shellac and pore filled with Z-Poxy. No problems yet, it was sprayed last summer.
Good judgement comes from experience. Experience comes from poor judgement.
PostPosted: Thu Feb 14, 2013 1:13 pm
First name: Blake
Last Name: Dixon
City: Kelowna
Cool That is what I have planned as well, sealing with Shellac, however my question to all is (if I dont need the cardnial sealer then I wont order it.) Correct? Any advice would be appreciated.
Blake.
Blake Dixon
Kelowna B.C.
PostPosted: Thu Feb 14, 2013 3:28 pm
You are much better off to use the proper sealer. Shellac and lacquers have changed a good bit chemically . There are many examples of adhesion issues . There is a reason they suggest using the sealers. Yes I know many of you use shellac , but it is a gamble. This is more about compatible chemistry over time.
PostPosted: Thu Feb 14, 2013 4:10 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
John is correct, modern lacquers are highly engineered coating systems, for best results you should work within the system. I even discourage using brand A sealer under brand B finish for that reason. Plus if you do have an issue the only way their tech dept. can even begin to assist you is if you used their system start to finish, anything else is an unknown.
Brian
PostPosted: Thu Feb 14, 2013 10:58 pm
+++ What John and Brian have said. Why in the world would one compromise all the work that has gone into a guitar build and finish prep with materials that aren't formulated by the manufacturer of the finish that you use? This only opens the door to problems or complete failure. Mixing materials that aren't designed by the manufacturer for the optimal end result only invite warranty repairs that your finish supplier will not be able to support you with. Use the WHOLE system that is designed for the finish you are using and learn to use it correctly as designed.
jw ( o)===:::
PostPosted: Fri Feb 15, 2013 10:03 am
City: Tyler
Best person to ask is Cardinal.... Seems like an easy question... "will shellac be okay under your finish?"
PostPosted: Fri Feb 15, 2013 8:45 pm
There are also a lot of lacquer on bare wood only finishes out there with no issues.
PostPosted: Sat Feb 16, 2013 1:00 pm
Darrel, I'm one of those bare wood lacquer people. Have never had any adhesion problems, and I've used Mohawk, McFadden's/Seagrave, Cardinal, and even G.J. Nikolas back in the late 70's & early 80's. If I'm not mistaken, Howard Klepper is bare-wood finisher also.
michael propsom
www.propsomguitars.com
Users browsing this forum: Ken Lewis and 41 guests
