It is currently Sun Aug 17, 2025 9:44 pm
PostPosted: Tue Feb 12, 2013 1:54 pm
First name: Darryl
Last Name: Young
State: AR
I need to order sandpaper for my random orbit sander (ROS). I have an old 334 Porter Cable which has a 5" PSA pad so hook and loop won't do. I recently tried a ROS on the back and top for the first time and I don't want to go back to hand sanding those areas <smile>. It sure leaves a nice, sleek finish.
I only use this for finish sanding so only need higher grits. I need a replacement roll of 220g for sanding prior to pore filling; otherwise, I'm thinking I should get 400-600 for sanding zpoxy etc. Anyone tried level sanding a finish with a ROS?
So what grits do you use, what brands do you use, and where do you buy it?
For the record, all I've tried is 415N TRI-M-ITE Fre-CUT A wt paper.
PostPosted: Tue Feb 12, 2013 2:21 pm
I've just started using 3M Fre-cut gold 216U. I really like it. It last a long time, doesn't load up, and is compatible with water based finishes (non-stearated). The best prices I found were on Amazon.
Best.. M
PostPosted: Tue Feb 12, 2013 2:29 pm
First name: Darryl
Last Name: Young
State: AR
Are all sterates bad for finishes? Reason I ask is I had Carborundum Premier Red Dry-Lube paper recommended to me for sanding finishes. I bought this and used it on my first build. It sanded great and I didn't notice any adhesion issues. Now while reading about this paper for my ROS, I see it has some form of sterate applied.
PostPosted: Tue Feb 12, 2013 4:21 pm
I've just read that stearates can cause fisheye problems with water based finishes. The places that sell the 3M fre-cut paper tend to be automotive painting suppliers. Most cars are base coat (water base) clear coat (solvent based) these days.
Just trying to eliminate any possible problems.. [:Y:]
PostPosted: Wed Feb 13, 2013 6:22 am
I like Mirka Gold. I find it to be similar to the 3M
PostPosted: Wed Feb 13, 2013 11:27 am
First name: Darryl
Last Name: Young
State: AR
Would someone with a little insight mind addressing sterates a bit? Are they all bad?, which brands are safe?, etc.?
PostPosted: Wed Feb 13, 2013 1:52 pm
First name: Chuck
Last Name: Gilbert
City: Magnolia
Zip/Postal Code: 77355
I have used Norton 3X on the past 30 or so guitars and have never seen any finishing problems though their website says that it has "waterbased stearate (anti-clog) coating". After level sanding I always wipe all surfaces with a cloth dampened in clean, filtered water between coats so maybe that helps. I really like the product, though.
Chuck
PostPosted: Wed Feb 13, 2013 3:31 pm
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
I've been using Abranet on my 6" ROS with dust port/vacuum for sanding prior to fill/finish. Works a treat! Still flatten/polish the top finish coat by hand though.
Dave F.
Cambrian Guitars
PostPosted: Sat Feb 16, 2013 2:38 pm
First name: Darryl
Last Name: Young
State: AR
FYI, I called Carborundum and asked about the sterate used on their Premier Red Dry Lube paper. The gentleman I spoke with contacted the product manager and he stated the sterate they currently use is compatible with solvent and water-based finishes. He specifically stated it is compatible with lacquer finish.
