It is currently Mon Aug 18, 2025 11:35 am
PostPosted: Tue Feb 05, 2013 4:31 pm
Last Name: G
Hey guys, I've got a vintage Gibson that's got some bellying. Forgive my question for being obvious, but I just want to confirm before I go ahead and start doing anything. Let me say that while I have never performed a repair like this, I am confident enough in my ability to successfully complete each stage of the process.
Ok, so I would like to remove the bridge and bridge plate, then glue new ones in. But my questions is, after I've removed the pieces, if I clamp down the top so it's is about where it needs to be, then I glue the new bridge plate and bridge on, will those pieces be enough to hold the top in place? Or will it belly again?
I intend to make a maple bridge plate, in place of the spruce one that's currently in there.
Does that make sense?
PostPosted: Tue Feb 05, 2013 4:51 pm
Last Name: G
Well I believe that this is the case, but let's just say theoretically what I described was a situation, would gluing a new bridge plate and bridge hold a bellied top down?
edit - it is properly humidified, braces are glued good,
guitar is a 1956 gibson lg1, ladder braced, spruce bridge plate, bellying is a very common issue with this model, solution is usually glue a bridge plate overlay or a new bridge plate all together
PostPosted: Tue Feb 05, 2013 5:37 pm
Is this affecting the playability and/or tone of the guitar, or is it a cosmetic issue?
https://soundcloud.com/jeffreylsuits/he ... -runnin-13
PostPosted: Tue Feb 05, 2013 5:56 pm
Last Name: G
It is affecting the playability. The action is too high. I don't care about cosmetic issues. I set up guitars for a living so I know this is the reason.
It doesn't affect the tone either. This guitar sounds incredible. That's why I need to fix it, I believe this guitar is a keeper, I think she'll be with me my entire life.
The bellying is about a half cm to full cm. A little closer to half cm.
Action is about a half cm too high.
PostPosted: Wed Feb 06, 2013 2:39 pm
First name: David
Last Name: Radlin
City: Belle River
Zip/Postal Code: N0R 1A0
Why not install a JLD Bridge Doctor?
David Radlin
http://www.facebook.com/radlin.guitars
PostPosted: Wed Feb 06, 2013 8:36 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I always thought bellying is pretty natural... but if the action is high what about a neck reset? An alternative to replacing the bridge plate is a bridge plate overlay, if it is cracked across the string hole and the holes are worn out. It's 10,000 times easier than replacing the bridge plate. I much rather take the whole top off (to piece it back together, in the case of a severely cracked top) to replace the bridge plate.
Typhoon Guitars
PostPosted: Thu Feb 07, 2013 3:03 am
Last Name: G
Nah, I don't really like the bridge doctor.
I don't think this guitar is a candidate for a neck reset. The bellying is minor enough that with 11s on and tuned down a step, she plays pretty decent. So I'm getting some good use out of her at the moment. Although the strings are a little loose.
I have considered a bridge plate overlay, but I figure I might as well just replace the whole thing. Also I think the new bridge plate would hold the bellied top down better.
Users browsing this forum: mikeyb2, phavriluk and 21 guests
