It is currently Tue Aug 12, 2025 2:22 am
 Post subject: Need help!
PostPosted: Wed Jan 02, 2013 9:45 pm
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
Hi Folks; It's been a long while since I dropped in, but things have settled down (at last) & I'm back into the shop full time again.
A customer recently brought me a 1965 Patt Lister Classical guitar that's in need of major repair.
The repairs are going well, but I am having trouble finding new tuners to fit the 1.5" post spacing. All of the current production tuners seem to have 1.378" spacing.
I have ordered a set of individual Shertlers that'll do the job, but they will look out of place on this old instrument.
Does anyone know where I can find some good quality tuners with the right spacing?
Thanks in advance. Dan
 Post subject: Re: Need help!
PostPosted: Wed Jan 02, 2013 11:21 pm
First name: William
Last Name: Snyder
City: Brooklyn
38.1mm spacing is going to be tough to come by. I've never seen any but seem to recall reading a similar question to yours once before. I think Gotoh makes tuners with 39mm spacing. You'll probably have to look around or special order, though. You might check to see if those would work.
Edit: Just did a quick search and found the Gotoh's here (again, don't know if they'll work):
http://savageclassical.com/shop/gotoh-4 ... -machines/
PostPosted: Thu Jan 03, 2013 1:00 am
You might consider Gilbert individual tuners also. A very good tuner, not as non-traditional looking as the shertler, but some don't care for the aesthetics.
PostPosted: Fri Jan 04, 2013 3:06 pm
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
Thanks guys!
I lucked into a set of almost identical tuners from a friend who's been carting them around for almost 40 years. Luckily, he bought two sets back in the early seventies & didn't mind parting with one set. Problem solved.
This is a really unique old guitar. Designed & built by an Aircraft Maintenance Engineer who threw out traditional bracing methods & applied his aircraft structural expertise to the bracing.
The braces are 1/16" thick & 5/8" tall, radiating out from the soundhole. The braces are jointed to 1/16" thick rings spaced concentrically out from the soundhole. Very light & extremely stiff.
Apparently, Segovia played this guitar during a master class he held in Toronto in '66 & was very impressed with it. The owner has a picture of Segovia posing with the students in the class.
If I can get a good pic of the bracing, I'll post it once the repairs are finished.
Cheers! Dan
PostPosted: Sun Jan 06, 2013 8:20 pm
First name: David
Last Name: Wren
State: ON
Zip/Postal Code: M4C 4X5
Sergei de Jonge worked with Pat for a time ... he'd be a good source of information on Lister guitars if you have further questions.
PostPosted: Sun Jan 06, 2013 8:26 pm
I know your problem is solved, but for future information, Rubner, in Germany will make tuners for any spacing you want. You'll pay a premium for them, but their machines are reasonably priced, and a premium set will still be less than lots of other machines, and you can get the special spacing or 5 on a side, what ever you want.
Users browsing this forum: No registered users and 45 guests
