It is currently Fri Aug 15, 2025 4:07 pm
PostPosted: Mon Nov 12, 2012 8:51 am
First name: EddieLee
Last Name: Brown
I am preparing to send my first steel string out to be finished. I do not have clear information on how to handle the area on the guitar body that the fretboard covers. I am assuming that the finish must be removed from this area before the fretboard extension is glued down. I see that some folks mask off that area before finishing and others do not. If you do not mask off this area, how is the finish removed? What are the advantages and disadvantages of each method?
Eddielee
_____________
EddieLee
PostPosted: Mon Nov 12, 2012 9:38 am
Last Name: coloccia
Country: States
re: routing off
The kitchen plastic wrap I have here is just about .001" thick. I think my aluminum foil is about .005"...maybe a touch more. You can combine layers on the bottom of your router base, punch a hole in the middle, put the router on a flat surface and then just set the router height with the bit sitting flush, you can very quickly get a pretty precise depth.
PostPosted: Mon Nov 12, 2012 1:44 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
If you decide to mask off, check with your finisher and make sure whatever you are using to mask is compatible with the finish.
Brian
PostPosted: Mon Nov 12, 2012 2:08 pm
Last Name: Vallandigham
City: Martinez
I prefer to just spray the whole dang thing, then locate the fingerboard extension and bridge, scribe and chisel off.
My finish (oil varnish) sticks really well, but after I get most off, I start scraping till I get down to bare wood.
No set-up, and the resuly is clean.
I have seen at least one bridge (not mine) that was masked and the the bridge pulled off (clean) after about a year. I always suspected that it was the maksing tape stick-um that may have been the perp.
BUT, many, if not most builders do it this way.
PostPosted: Mon Nov 12, 2012 2:58 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
My last 2 used the frisket film http://shop.hobbylobby.com/products/9-x-12-matte-extra-tack-prepared-frisket-film-129791/ as suggested in a past topic and love the results, it is much thinner than making tape and after scoring the edges pulled up real easy and clean. I left it on the whole time through finish, curing, level sanding and buffing about 6 weeks and it was no problem removing. As suggested above check with your finisher to see what he prefers. I don't have that issue as I am a believer in building the entire guitar myself so do my own finishing.
Fred
Fred Tellier
PostPosted: Mon Nov 12, 2012 3:14 pm
First name: Peter
Last Name: Johnson
Country: Ceridigion, Wales
Scrape ?! I just use paint stripper, much easier. Apply to edges of scored outline with a artists brush. 2 minute job. I suppose masking is probably the best method tho.
peter
PostPosted: Tue Nov 13, 2012 11:09 am
Last Name: Brown
Thanks - Great info bliss
EddieLee
_____________
EddieLee
