It is currently Sun Aug 03, 2025 7:22 am
PostPosted: Fri Nov 09, 2012 1:18 pm
First name: Stuart
Last Name: Gort
I'm trying to locate some of that hard, pressed, colored paperboard material that is used to make thin layers in laminates but I can't remember the generic name by which it is called. If someone could say....or possibly recommend a good supplier of that material I would appreciate it.
Thank you.
StuMusic
PostPosted: Fri Nov 09, 2012 1:50 pm
Last Name: Sonksen
City: PORTLAND
State: Oregon
Zip/Postal Code: 97216-2013
Phenolic?
PostPosted: Fri Nov 09, 2012 1:52 pm
Last Name: Ball
Vulcanized fiberboard?
PostPosted: Fri Nov 09, 2012 2:02 pm
Fiber Veneer sheets.
http://www.lmii.com/CartTwo/thirdproduc ... eer+Sheets
PostPosted: Fri Nov 09, 2012 2:32 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
My Formica supplier simply calls it phenolic backer.
Brian
PostPosted: Fri Nov 09, 2012 3:07 pm
First name: Pete
Last Name: Liccardello
City: Eden Prairie
State: Minnesota
Fishpaper; AKA: vulcanized fiber sheet. "Available in thinner gauges, typically from .0078" to .062" thick. Available in Grey (standard), Black, Blue, Brown, Red & White."
http://www.professionalplastics.com/FISHPAPER
Peter
Users browsing this forum: bobgramann and 18 guests
